Member's Forum How do you make reliable, low-cost cables quickly?
  • Replies 52 replies
  • Subscribers 549 subscribers
  • Views 4102 views
  • bootlace connectors
  • custom cables
  • MTA
  • Yodamonk
dougw
dougw over 1 year ago
I do lots of electronics design and building and inevitably need to make lots of cables. Since making cables is not my favorite activity, I try to use methods that are quick while still providing reliable connections. And of course I always need to keep the costs down.
This short post shows a couple of the main ways I accomplish these objectives.
Yodamonk, the cable guru.
Custom Cable Methods
Discussion
I haven't posted much content lately so I thought I would post something about making cables. This activity is not usually exciting enough to be a great blogging topic, but I also wanted to play around a bit with some AI media generation. (No AI text though) The tough Yodamonk dude came out amazing.
I am always looking for efficient ways to make useful cables, so if you have any interesting tips, please jot them down below...
  • rsc
    rsc over 1 year ago in reply to wolfgangfriedrich +4
    When I worked at Chrysler, I learned a nice way to document cables using this technique: 1) Have a picture of the end of the connector and label the connector with part number and manufacturer. 2)…
    shabaz over 1 year ago in reply to dougw +4
    Here they are dirt cheap from CPC (a Farnell/Newark company). Maybe this brand might be available in your country too.
  • phoenixcomm
    phoenixcomm over 1 year ago +3
    dougw Oh, my favorite hatted thing to do in the shop! Before we can build a custom cable you have to take a long look at "TOOLING" Well if you are working with mill connectors, which I do, they come in…
    dougw over 1 year ago in reply to shabaz
    Newark does sell them, although they all seem to have flanges.
    Oh.. the metal flange is useful for gathering the strands. You definitely want them without flange?
  • beacon_dave
    beacon_dave over 1 year ago in reply to shabaz
    Perhaps need to be careful when going cheap that they are still DIN 46228-1 etc. so as to get a consistent crimping quality.
    shabaz over 1 year ago in reply to beacon_dave
    I've used that brand for a few years, they are tinned copper (like the DIN standard requires). The dimensioning tolerances might be different though. But even with the DIN standard, there's actually very few guidelines on wire thickness matching to ferrule size, and a lot of the ferrule crimpers have just the single hole for accepting all sizes of ferrules. But agree one shouldn't cheap out for a critical application. And definitely avoid complete no-name products which might not even be the correct material.
    Both types would be useful.
  • Andrew J
    Andrew J over 1 year ago in reply to dougw
    I have a bunch of these and they’re very useful. In fact, I had to dig them out to help with a 3D Printer I’m in the middle of building.
    They are also useful as test points on a board, at least with through holes but I’ve not tried soldering one to a pad.  If you push it through the hole on the PCB, the flange will stop it falling through and your probe end will slot neatly inside and be held freeing a hand up.
  • rsc
    rsc over 1 year ago in reply to dougw
    If I build something for someone else, I try and pack a schematic inside the enclosure just in case someone in the future needs to work on it.
  • beacon_dave
    A while back I had some ferrules that tended to stick in the die of the crimp tool after crimping. I think the standard helps more with that aspect nowadays.
    With the insulated types it can sometimes be difficult to get a good fit on both the conductor and then on the insulation.
  • beacon_dave
    beacon_dave over 1 year ago in reply to dougw
    You'll be wanting 'aglets' next for your shoelaces Mans shoeMans shoe  Slight smile
