Member's Forum This toy sucks
  • Replies 24 replies
  • Subscribers 551 subscribers
  • Views 1909 views
  • Vacuum Cleaner
  • amazon prime
  • hack the vacuum
  • henry hoover
  • portable vacuum
  • modding
This toy sucks
stanto
stanto over 1 year ago
The amazon prime sale is ending today, and in the post I received this little chap:
I thought that it was a gimmick. No way this little thing that runs on three AA batteries would do anything. I gave it a go anyway and attempted to clean the front of my computer.
How surprised I was.
It performed really well!
I am now thinking it would benefit from a bit of modification, a second grille over the air 'intake' inside the vacuum, so that the 'filter' which is a sponge, doesn't directly get filled with dust.
I am also curious if I can increase the power capability, maybe I should do a teardown and check it out. It'd be great if I could 'connect it to mains' such as USB for an added boost, but otherwise use battery power.
Also it's cute.
    dougw over 1 year ago in reply to bradfordmiller +4
    Hmmm.... its a Henry Hoover ... presumably that means it hoovers up henrys .... If a Henry Hoover could hoover henrys, how many henrys can a Henry Hoover hoover?
  • battlecoder
    battlecoder over 1 year ago in reply to bradfordmiller +3
    I want to know the inductance of the motor coils. They should be exactly one Henry ;)
  • kmikemoo
    kmikemoo over 1 year ago in reply to stanto +3
    stanto The deflector is the simplest path. The cyclone dust collector... less simple. phoenixcomm I did try to build my own. I was unhappy with the results/functionality. I haven't given this one…
  • kmikemoo
    kmikemoo over 1 year ago in reply to phoenixcomm
    phoenixcomm That's a bad day at the office. Joy
  • beacon_dave
    beacon_dave over 1 year ago in reply to kmikemoo
    They managed to fit the square peg into the round hole...
  • stanto
    stanto over 1 year ago in reply to kmikemoo
    Thanks, that's very helpful.
  • phoenixcomm
    phoenixcomm over 1 year ago in reply to kmikemoo
    You have a problem with your air intake as pictured above. I show to be in line with the desired flow which means you will not make a tornadic effect. The inlet should be parallel to the side so the air will spin.
