Member's Forum What is the function of the hole in the centre of a sponge?
  • Replies 16 replies
  • Subscribers 594 subscribers
  • Views 1812 views
  • sponge centre hole
HKPhysicist
HKPhysicist over 1 year ago
Hello Friends,
Is there any function of the hole in the centre of a soldering station sponge?
For instance, this one:
https://hk.element14.com/metcal/ac-ys3/sponge-workstand/dp/4950483
I have 2 sponges from 2 different soldering stations.  Both of them have big holes in the centre.  Thinking
  • anniel747
    anniel747 over 1 year ago +9
    Deleted
  • beacon_dave
    beacon_dave over 1 year ago in reply to anniel747 +4
    I find that it helps contain the contaminants after you scrape them off, leaving the rest of the sponge clean for the final wipes of the tip.
    shabaz over 1 year ago +4
    https://youtu.be/cSFLWEU9_Ok?feature=shared
  • HKPhysicist
    0 HKPhysicist over 1 year ago in reply to anniel747
    This seems a practical function of that hole.Thinking
  • mp2100
    0 mp2100 over 1 year ago in reply to shabaz
    Wow.  You solved it, It’s a koan.
    I was thinking more along the lines of ”now they know how many holes it takes to fill the Albert Hall”
  • phoenixcomm
    0 phoenixcomm over 1 year ago in reply to dougw
     dougw NOPE! Try again. ROFL!! Really just to scrape crud and detritus from your Irons tip! anniel747  I think your sponge is dry! run it under the water tap. Remove and Squeeze to Damp!  (then retin the tip) ~~ Cris H.
  • phoenixcomm
    0 phoenixcomm over 1 year ago in reply to Jan Cumps
  • me_Cris
    0 me_Cris over 1 year ago
    Maybe to pour water, and being in the center it will be absorbed better.
  • kiranmr69
    0 kiranmr69 over 1 year ago
    1. Wiping the Soldering Iron Tip: The hole provides a place to press the soldering iron tip gently against the sponge to clean off excess solder or oxidation without damaging the tip.
    2. Holding Water or Moisture: The hole can help retain water, ensuring the sponge stays damp for effective cleaning. A moist sponge prevents overheating and oxidation of the soldering iron tip during cleaning.
    3.Shaping or Positioning: The hole allows better access for shaping or angling the tip while cleaning, especially for specific tip designs or cleaning needs.
