Member's Forum QUESTION OF THE MONTH: What type of screwdriver head do you prefer?
  • Replies 32 replies
  • Subscribers 595 subscribers
  • Views 45090 views
  • element14members
  • poll
  • question of the month
  • screwdriver
vijeth_ds
vijeth_ds over 1 year ago
e14 Question of the Month
There are many types of fasteners available in the marketplace. Selecting the right type of fastener often depends on the job to be accomplished. Each type of fastener often has a matched screwdriver head type.
  • beacon_dave
    beacon_dave over 1 year ago +6
    vijeth_ds said: What type of screwdriver head do you prefer? The one that matches the head of the screw that I'm trying to remove.
    dougw over 1 year ago in reply to ntewinkel +3
    When I say square I mean Robertson.
    shabaz over 1 year ago +3
    I'm going to answer a different question : ) I really like Wiha System 6 interchangeable tip screwdrivers - nice large range of tips. But prices have more than doubled so it's not very viable any more…
    For performance and ease of use, I prefer square.
    When removing a screw the obvious choice is whatever the screw dictates.
    When choosing what to stock, I go with the cheapest stainless steel screws I can find that don't use a slot. Unfortunately this usually means Phillips.
  • ntewinkel
    ntewinkel over 1 year ago
    Robertson is missing from the list. It’s very similar to square drive but specifies a tapered design that’s a step better.
    I really like Wiha System 6 interchangeable tip screwdrivers - nice large range of tips. But prices have more than doubled so it's not very viable any more. I purchased more than 10 years ago, and they're still going strong.
    But a very close second for me are Vessel screwdrivers - they have JIS compatible drivers (which fit Japanese equipment well, if you're doing consumer electronics repairs, but also appear to fit normal Philips screws quite effectively too). A lot more affordable.
    I've tried 'Megadora' and their ball-handle screwdriver (which are super-comfortable to grip). Not been disappointed so far.
  • ntewinkel
    ntewinkel over 1 year ago in reply to dougw
    Tbh, I tend to use whatever square head screws and screwdrivers are available. But I have noticed some just perform better.
  • ntewinkel
    Amen to that! Those are the worst!
    But slotted screwdrivers are handy when the Phillips hole is stripped - use a dremel to create a slot and you get a second chance.
    Jan Cumps over 1 year ago
    When I worked at a truck assembly plant (DAF Trucks in Oevel, Belgium), it was Posidriv all the way. Except exceptions Slight smile.
    These are actually easy to use with powered tools, once you get the hang of it.
    At the end of my stint there they started to use Torx, That has advantages, but it's harder to get the bit of a powertool removed once the screw is tightened, Tends to "stick/bite" a little.
    edit meanwhile:
  • kmikemoo
    kmikemoo over 1 year ago in reply to ntewinkel
    I do prefer the combination Phillips / Slotted screw heads if it has to be Phillips.
  • anniel747
    anniel747 over 1 year ago in reply to kmikemoo
    Jan Cumps over 1 year ago in reply to kmikemoo
    Advantage of Posidriv over Phillips, is that a slow turning powertool will grab into a Posidriv, but not in a Phillips.
    At a production line, it means that you can get grip by giving the machine a little oomph. With a Phillips it will skip over. You have to align the bit somewhat when attacking a Phillips.
    A Posidriv screw also sits better on a magnetic screwdriver, if you have to reach deep to mount a screw.
