Member's Forum QUESTION OF THE MONTH: What version of the Raspberry Pi did you use in your last Pi project?
  • Replies 23 replies
  • Subscribers 547 subscribers
  • Views 2815 views
vijeth_ds
vijeth_ds 8 months ago
e14 Question of the Month
The Raspberry Pi single board computer (SBC) is one of the most favorite SBCs in the market today. It's been around for about 13 years and lists ten versions to date (Feb. 2025). While the Raspberry 5 is the most recent version of the Pi and some versions are no longer manufactured (e.g., 1A+, 1B, 1B+), there are earlier versions of the Pi still in use today.
    dougw 8 months ago +3
    My last Raspberry Pi project used four Pi's - a PI 4B, a Pi 3B, two Pi Zero 2Ws and a Pico. I also tried a Pi 4 Compute Module, but it didn't make it to the final apparatus.
    Jan Cumps 8 months ago +2
    I'm currently using the small size 1A+ as LoRaWan gateway, and AVNET's custom SmartEdge IIOT Gateway (based on the Raspberry Pi 3 Compute design). The 1A+ is powerfull enought to run a The Things Network…
  • BigG
    BigG 8 months ago +2
    Where does Raspberry Pi Zero W & Zero 2 W fit in?
    0 shabaz 8 months ago
    Pi 3B+... low price compared to the later higher-memory models, and legacy code libraries work on it, and no excessive power requirements either.
    If its insufficient I consider Pi 4, since I'm unsure how mature Pi 5 software is, nor aware of the power and heatsinking requirements.
    But currently, I use the Pi Pico way more frequently, even if it needs connecting to a PC or other device  to do the heavy processing.
    • Vote Up -1 Vote Down
  • md_steve
    0 md_steve 8 months ago
    The last little thing I built was a network monitor that tells me when my wife is almost home. I used an older Pi just because I don't need much processing power to monitor the network for her car's IP address. When she is a few hundred meters away the car connects to the network and the Pi alerts me to turn on the outside lights and unlock the door for her.
    Maybe I'll automate the lights and front door some day, but for now it's perfectly simple. I have just about every version of Pi but there's no sense using a $60 unit when an unused $25 device will do. Of course I also could have used a Pi Zero but then I wouldn't have finished this 'project' in one afternoon.
  • BigG
    0 BigG 8 months ago
    This makes things more interesting... there's a new CM4 announced by Raspberry Pi with extended temperature range ( -40°C to +85°C).
    https://www.raspberrypi.com/news/new-extended-temperature-range-for-compute-module-4/
