Ask an Expert Forum Can anyone recommend alternatives to CAP - MC0805B104J500CT due to availability issues?
  • Subscribers 309 subscribers
  • Views 586 views
  • components
  • electronics
See a helpful answer?
kruti
kruti 10 months ago
    shabaz 10 months ago +2 suggested
    It looks in-stock here currently (qty 34,000 available): https://uk.farnell.com/multicomp-pro/mc0805b104j500ct/cap-0-1-f-50v-5-x7r-0805/dp/2320839?srsltid=AfmBOoqDdsjOZEnzbJZU1erFBwS70at0Vm3lb_99IL1e6fEyrGADmVcG…
    0 shabaz 10 months ago
    However, it looks very "basic" and easy to source an alternative, you can most likely replace it with any other ceramic capacitor of the same size (0805), provided it is also X7R, 0.1 uF, 50V.
    Here's a suitable list:
    https://uk.farnell.com/w/c/passive-components/capacitors/ceramic-capacitors/smd-mlcc-multilayer-ceramic-capacitors?capacitance=0.1uf&voltage-dc-=50v&capacitor-case-package=0805-2012-metric-&dielectric-characteristic=x7r&capacitance-tolerance=posneg-5pc&range=inc-in-stock
    Of course, you should get an electronics engineer to check any substitutions and run some tests. But it's very likely there will be no issues if you follow the advice mentioned here.
