Member's Forum WARNING ! AI rots your Brain
  • Replies 47 replies
  • Subscribers 548 subscribers
  • Views 1867 views
michaelkellett
michaelkellett 4 months ago
From yesterdays Telegraph:
The article is based on work done at MIT
https://www.media.mit.edu/projects/your-brain-on-chatgpt/overview/
https://www.brainonllm.com/
If you follow the second link you can eventually find  .pdf of the full research paper (if you've been using ChatGPT a lot recently you may struggle.)
You have been warned !
    dougw 4 months ago +5
    This is a no-brainer. But what does AI have to say for itself on the topic?
    dougw 4 months ago +4
    Calculators rotted our brains. Search engines eliminated the need to learn. AI eliminates the need to think. At risk is human creativity.
    Jan Cumps 4 months ago +2
    michaelkellett said: (if you've been using ChatGPT a lot recently you may struggle.)
    shabaz 4 months ago in reply to shabaz
    Just remembered a few Excel stories..
    My manager used Excel heavily.. He had built up a complex system of sheets and formulae, and he could generate a report sheet and charts, but only he could use it, and if senior management wanted to see something subtly different, then to produce the new output he would spend the day debugging his spreadsheet, because so many cells were chained together through the formulas. He wasn't a developer; he didn't know how to insert the information into a database and run queries. No business intelligence software was easy for an individual to set up or to subscribe to and use back then.
    Another colleague used to generate product configuration files, i.e., technical content files, using Excel. That was massively complex too, to the point that whenever I saw him, he was more often than not sitting in front of his spreadsheet, forever tweaking it for any slight changes the customers asked for. It became his job, which was quite depressing because he could have done loads more if he could have offloaded it.
    And yet, on the flip side, as mentioned, Excel has probably been responsible for being the key software for millions of businesses, too.
  • dang74
    dang74 4 months ago in reply to shabaz
    shabaz said:
    Just some more random examples; I can see it in myself with books; if I don't read fiction for pleasure for a while, then it takes me half a dozen pages before it clicks that I'm not absorbing and am only scanning, and I have to go back and re-read and get back into the 'mode' of actually enjoying the book.
    Interesting.  I have a similar problem with fiction.... where it takes me about 10 pages to get used to the 'author's voice.'
  • aswinvenu
    aswinvenu 4 months ago
    Just makes me thinking..
    Auto-complete has been playing a big role in people's ability to remember spellings and details.
    Even while coding I have noticed that those who use auto complete don't tend to remember the details of the functions etc.
    Jan Cumps 4 months ago in reply to aswinvenu
    That leaves more brain bandwidth for other things. There are so many APIs out there. It may make sense to memorise the ones you use daily. But all others: let the tools do the work?
  • aswinvenu
    aswinvenu 4 months ago in reply to Jan Cumps
    Fair point! But will it affect the ability of people to focus on details? I am not saying they have to remember all the APIs. What I have seen is ( especially while taking interviews ) people who are so used to autocomplete struggles to put a fully functional code in place, even with some basic functions.
  • javagoza
    javagoza 4 months ago in reply to aswinvenu
    We often forget, especially in human resources, that the purpose of hiring is to bring in people who can solve problems, not people who are just good at interviews.
    I count myself amongst that group.  I always refer to existing code, examples, previous blogs and google.
    If I haven't written a case: statement in the last few weeks, I need to google it.
    genebren 4 months ago in reply to Jan Cumps
    I feel the same way.  I have never strived to remember syntax, or parameter positions in a function call, as there are plenty of sources for those answers. Code completion tools can help with that.  What I do focus on when writing code is make it readable and functionally sound.  I have known people with great recall that can't program to save their lives, because they don't have the skills to logically break down problems into pieces and then to utilize the pieces in a concise way.
  • kmikemoo
    kmikemoo 4 months ago in reply to shabaz
    shabaz 4 months ago in reply to genebren
    I use the AI tools to help with code completion, and API discovery too.
    Here's an example.
    Through usual experience, I know that if I want to calculate the radius of a circle from the area of it, then math.h will have a function to perform the square root. But I don't need to remember the parameters, nor even the name of the function.
    In the screenshot below, you can see in gray text that the AI-powered auto-completion suggested the API function name for me, and the parameter too.
    It's in grey and up to me to accept it by pressing tab, or ignore and keep typing as normal.
    That API discovery is powerful, and it's not unusual that it can find a better function than I might have chosen.
    Notice I don't have the constant M_PI defined, but hovering over it tells me that. I either need to create my own definition of Pi, or use one in a library.
    Then, the AI can see I'm trying to print the radius, which is a floating-point value, so it auto-completed the string, and the variable name.
    All the time the user is in control, but can let the AI take over with this fine line-per-line interactivity, and override whenever it's desired. The user is still responsible for architecture and individual functions, just as if they were not using AI, but can get a speed-up to do the boring bits of filling in lines of code.
    It also encourages the user to write more descriptive variable names and code comments, since that's more input into the AI.
