Member's Forum Question of the Month: When you're choosing components for a new project, what influences your selection the most?
  • Replies 17 replies
  • Subscribers 548 subscribers
  • Views 1306 views
  • qotm
  • poll
  • question of the month
cstanton
cstanton 4 months ago
Component selection is a key part of every project, but the reasons behind those choices can vary widely. We’re curious—what factors carry the most weight when you’re deciding what to use?
Bonus Question:
Can you share an example where a specific factor—like availability or documentation—completely changed what component you ended up using?
    michaelkellett 4 months ago +4
    I voted: Detailed datasheets and documentation but only because it gets to veto any other consideration - if the part won't work or won't fit then it's no use. After that, it depends - for a quick…
    dougw 4 months ago +3
    I tend to choose components based on the following criteria - in order: What I have in stock Which component has the right features (including cost) for the application What is in my CAD library…
    DAB 4 months ago in reply to cstanton +3
    Cost only comes into play after you find a selection of components that do the job.
  • BigG
    BigG 4 months ago in reply to cstanton
    True, but with if weighted averages are used to tally up the votes, you'll likely get a clearer picture as to what the community values more highly.
  • cstanton
    cstanton 4 months ago in reply to BigG
    Fortunately people can express themselves in the comments Slight smile
    I voted:
    After that, it depends - for a quick test jig or proof of concept (both of which I do quite a lot) then availability quickly is often the primary consideration.
    For a job where I expect to make and deliver a few working prototypes then Availability from your preferred distributor is important.
    Manufacturer reputation is often a consideration, and more so when the design will eventually be built in large numbers.
    The significance of Eval boards and reference designs depends a great deal on the type of part and how different it is from similar parts that I may have used before.
  • dang74
    dang74 4 months ago
    A component's availability in stock is very important.  Whether it's stocked at a specific distributor is less important as long as its stock is well represented across the common distributors.  There is nothing worse than a product being held up by one or two hard to get components.
  • Gough Lui
    Gough Lui 4 months ago
    I'd go with [availability, price] as equally important, then [documentation, reputation]. In recent years, I've been more willing to take risks in design, since some things can only meet their commercially-viable price points if we take some level of creativity and risk by going away from more renowned manufacturers and into the darker depths of basing designs on more fragmented, incomplete documentation and reverse-engineered designs.
  • BigG
    BigG 4 months ago
    ESD components, for say Ethernet IO, and TVSdiodes for general IO can be tricky to get right. In these cases documentation is key.
  • aswinvenu
    aswinvenu 3 months ago
    This is a tricky question! Very hard to pick one from the given 5. It's definitely a combination of everything.
    I will definitely look for components from a reputed manufacturer most of them will maintain an good documentation. But if it's a hard to source part then I will look for alternatives.
    It also depends on the following items
    • What type of component?
    • Type of project.
    • Deadlines to meet.
    • End customer requirement.
