Member's Forum Programming PIC 16F628A
  • Replies 16 replies
  • Subscribers 572 subscribers
  • Views 1068 views
  • pic16f628a
jw0752
jw0752 over 9 years ago
I am looking for someone in the USA who has a PIC programmer and who would be willing to put a Program that I already have on a couple of PIC16F628 chips. I will supply the program and the chips. All postage paid and reasonable installation fee.
Send me an e-mail if you are interested.  johnwiltrout@att.net
Thanks John
    Former Member over 9 years ago in reply to jw0752 +2
    Here's some info on the Chipkit: ChipKIT MAX32 Development Platform
    jw0752 over 8 years ago in reply to bymccay +2
    Hi Brian, I found that there needed to be some termination on the crystal input when not in use. For this purpose I plug a 1 nF cap into the crystal socket. If you aren't going to use the crystal tester…
    jw0752 over 9 years ago in reply to balearicdynamics +1
    Hi Enrico, While experimenting with a small frequency counter kit I latched up the input on the 16F628. I ordered a couple more blank chips and found the original program on the internet but I do not have…
    Hi Brian,
    Here is a block diagram that I made for the counter, assuming that yours is the same as mine.
    Referring to the original circuit diagram the 1 nF cap ties the Crystal Oscillator to the input of the PIC. If you do not need the Crystal Oscillator in your application I would just remove the 1 nF cap from the circuit.
    This circuit was originally designed by a German Ham Radio Operator Wolfgang Buscher and subsequently hijacked by the Chinese for the little kits we are all enjoying. I had contact with Wolfgang when I was working through the bugs and functional problems that I was having. He is a great guy and didn't hold any malice towards the Chinese. If you google him or check out this address you can get more information on the original design.
    http://www.qsl.net/dl4yhf/freq_counter/freq_counter.html
  • bymccay
    bymccay over 8 years ago in reply to jw0752
    The 1 nf is where the test xtal goes, right.  68pf made it stable on.   But the other board is bonkers.   I'll try Wolfgang also.  Thanks,  Brian
    Sent from my iPad
  • bymccay
    I couldn't find a way to contact Wolfgang.  Also The link below you gave me doesn't work.
    Brian
    Sent from my iPad
    Hi Brian,
    The first link I put up didn't work so I edited the post and put up a working link. Make sure you are using the one that is currently displayed on the forum not the one that may have come with your first notification.
    No the 1 nF in the schematic is just a capacitor on the board that couples the crystal oscillator to the input of the PIC. The Other 1 nf  not shown in the block diagram that I mentioned was a loose capacitor that I put into the crystal socket to keep spikes from the oscillator from interfering with the external input. If I were to draw it on the schematic it would go between the Test Crystal Input and the Ground when no crystal is plugged in.
    Since there are several variations of this unit being sold from China I hope we are both talking about the same one.
  • bymccay
    That is where I put the capacitor from 10 pF up to 1 nF and the counter went bonkers except for 68 pF.   But the other counter I assembled it did not help.
    I found on wolfgangs site to  momentarily connect pins Four and five to change mode to count the one frequency.  This is my next test.
    Brian
    Sent from my iPad
