Member's Forum Arduino Serial
  • Replies 21 replies
  • Subscribers 632 subscribers
  • Views 2366 views
  • arduino serial stuff
Arduino Serial
roby1
roby1 over 9 years ago
Hi..i have a question, maybe a noob one for ppl who know. I have maked a counter each time when i press the button the counter increments with 1 and display on serial something like:
nr = 1, nr = 2, nr = 3 ...etc. What i wanna know and i have tryed over 4 days is how i diplay only once the value on a single line and each time when i count,  ""to somehow overwrite"" the existing value and displayng it like: ""nr = 1"" then on the same line 1 is replaced with 2..then with 3 and so on every time i count.  More simple, then same line remains unchanged and only the value get overrited (upgraded).
HERE IS THE CODE:
const int  buttonPin = 2;    // the pin that the pushbutton is attached to
const int ledPin = 10;       // the pin that the LED is attached to
// Variables will change:
int buttonPushCounter = 0;   // counter for the number of button presses
int buttonState = 0;         // current state of the button
int lastButtonState = 0;     // previous state of the button
void setup()
  pinMode(buttonPin, INPUT);
  pinMode(ledPin, OUTPUT);
  Serial.begin(9600);
void loop()
  buttonState = digitalRead(buttonPin);
  if (buttonState != lastButtonState)
    if (buttonState == HIGH)
      buttonPushCounter++;
      Serial.println("on");
      Serial.print("number of button pushes: ");
      Serial.println(buttonPushCounter);
      Serial.write('\n');
      Serial.write('\r');
    // Delay a little bit to avoid bouncing
    delay(50);
  // save the current state as the last state, for next time through the loop
  lastButtonState = buttonState;
  if (buttonPushCounter % 4 == 0) {
    digitalWrite(ledPin, HIGH);
  } else {
    digitalWrite(ledPin, LOW);
  Serial.flush();
  Serial.end();
  Serial.begin(9600);
  Serial.flush();
and i get something like this on serial:
on
number of button pushes = 1
on
number of button pushes = 2
on
number of button pushes = 3
on
number of button pushes = 4
on
number of button pushes = 5
etc.
and i want to get:
on
number of button pushes = 1 ----- and on this line 1 to be replaced with 2 at the next count, then with 3 and so on..
I have tryed Serial.print( '\r' )  for carryege return but didnt workt.
Can someone tell me where im wrong?? Or what i need to print so see what i want.
  • RParkerE
    RParkerE over 9 years ago
    You cannot do this with the Arduino IDE, it just does not support this functionality.
