Member's Forum Raspberry Pi I/O pins.
  • Replies 21 replies
  • Subscribers 631 subscribers
  • Views 1352 views
DAB over 8 years ago
Hi all,
I was doing some testing yesterday and discovered that the I/O pins on the RPi come up with interesting voltages on powerup.
I had just assumed that they would all come up at ground state, but we measured several pins and found them at 0.7, 1.2, 1.7, and 2.7 volts output.
We were trying to debug a driver circuit I designed, but noticed the default was at 1.2 volts and thought we might have a defective board. So we installed a brand new RPi 3 and found the pins at the above stated levels.
I am VERY disappointed in the RPi designers for not defaulting the pins to ground state until they are accessed by software.
Hopefully, they will correct this oversight in the next version.
Having random output levels could really do some damage to external circuits wired into an RPi.
    genebren over 8 years ago
    DAB,
    Not that this relates directly with your experiences with the RPi, but I have noticed a similar thing with a lot of microprocessors.  The default on power-up is to set all GPIO to Tri-State (High-Z) inputs.  This may be what you are seeing here.  This is, in the most general of cases, the safest state for the board (hopefully nothing enabled or driven, but not always the case).
    Gene
