Legacy Personal Blogs How one electrical passive element can cause issue
  • Author Author: kk99
  • Date Created: 26 Mar 2017 5:47 PM Date Created
  • Views 1772 views
  • Comments 9 comments
  • tv
  • service
kk99
kk99
26 Mar 2017
Few days ago I got TV with following issue: there is no way to power on TV (only standby LED is on). I have checked that all voltages on IP board (power supply and inverter) were correct. Next I have checked key elements on main board. After analyze of schematic I have found guilty: it was electrical capacitor 100 uF / 16V (C5068) located near 1.2 V LDO (placed under metal shield near the MCU). After replace of this element TV works properly.
    dougw over 9 years ago +2
    Good work, that must have been a very satisfying result.
    mcb1 over 9 years ago +2
    Well done. You'll be surprised how many LCD monitors suffer from faulty capacitors that prevent them from working correctly after a few years. As manufacturers have tended towards switch mode supplies…
  • COMPACT
    COMPACT over 9 years ago in reply to mcb1 +2
    There's now even lifetime calculators available. NICHICON CORPORATION | Product & Technology
  • COMPACT
    Did you measure the faulty component after its removal?
    It might have been giving you the short and curlies!
    jw0752 over 9 years ago
    Good detective work. Happiness comes with beating the system.
  • kk99
    kk99 over 9 years ago in reply to dougw
    dougw: Yes, especially when the riddle is good.
