Legacy Personal Blogs Replacing TV LEDS
  • Date Created: 8 Jul 2015 5:16 PM Date Created
  • Views 1789 views
  • Comments 8 comments
  • tv
Replacing TV LEDS
e14 Contributor
e14 Contributor
8 Jul 2015
Am looking for some generic part numbers to try out as replacements for individual surface mount white LEDs that have failed in TV backlights. They are used in strips of various numbers of LEDs in series and controlled by pulse width modulated regulated current.
  • Problemchild
    Problemchild over 11 years ago in reply to e14 Contributor +2
    As Shabaz says there are all sorts as you already probably know and the strip will be supplied as an assembly from the manufacturer and probably even they don't remember where they got them from. Have…
  • Problemchild
    Problemchild over 11 years ago in reply to e14 Contributor +1
    Probably sounds like robbing the LEDs from defective strips is the most practical way to go in the mean time at least if you have a large number of same/similar displays
    shabaz over 11 years ago in reply to e14 Contributor
    Hi Jerome,
    There are some "standard" sizes of LEDs, but also unusual sizes, and the variations beyond that are quite large in terms of viewing angle, color temperature, etc as you say. Even within a main part code they may also be binned to match so that the LEDs in a strip are consistently bright. Possibly you may want to purchase a few dozen or so different types in the size you need, and experiment with them. I think it will be difficult to achieve a match in this manner, but perhaps it can be "close enough" - I've no idea though, this is just a guess. : (
    I've never opened up a TV with LED backlight - could you post a photo of a typical strip showing the LED?
    After you've measured an LED up as precisely as you can, you can see the LEDs here http://uk.farnell.com/leds-high-brightness-high-power-white-over-75ma and attempt to match at least the physical size and take a guess on the color temperature (or use a test card) and viewing angle.
    e14 Contributor over 11 years ago in reply to e14 Contributor
    That information does not apply. I don't want to replace the strips, just the individual white LEDs that have failed on the original strips. I need to match the surface mount package, lense, light output, current, voltage, and color temperature. There must be some generic part numbers that can be ordered from distributors that are similar to those the TV manufacturers use. There would have to be some experimentation required and a variety of parts may be required. I would be sharing this information with TV servicers in a group that I belong to. Most modern TVs are not economically repairable if we can not repair them at a component level.
    Between eBay and YouTube, there is a myriad of information.  To start with you will need to get the panel's model #.  It's VERY different from what's on the back of the cabinet.  Pull the screen and look for a sticker on the back.  You start from the model # you find.
