Legacy Personal Blogs Throwing in the towel | HLH
  • Author Author: baldengineer
  • Date Created: 1 Apr 2018 6:01 PM Date Created
  • Views 1805 views
  • Likes 8 likes
  • Comments 14 comments
baldengineer
baldengineer
1 Apr 2018
Last night I had strong hopes I would be recording my first gameplay video before going to bed. However, that did not happen.
As of this writing, the screen is working. Most of the buttons work. Except, when controlled by the Pi. When the Teensy and Pi are connected, it appears to create a short circuit. The troubling aspect is that when the Teensy is connected to my computer, no issue there. At least I have a Wii-U style controller for OpenEmu now. image
So the problem is with the Teensy, the Pi, or my wiring. I suspected the wiring first but cannot find an obvious fault. After that, I programmed a new Teensy but did not connect any wires. I get the same behavior by just connecting to the Pi’s USB, which is why I suspect the Pi. Perhaps I damaged the USB controller when de-populating the USB ports. When the kernel driver enables the USB controller, I see the 5 volt rail dip, the under voltage icon comes on (when the screen is connected), and sometimes the Pi reboots. If it makes it to EmulationStation, I can SSH in and see dmesg complaining about overcurrent.
Regardless, I have yet to start editing my video. Even if I could find and repair the fault in the next hour, I would not have time to finish a suitable video by the morning deadline.
I have never captured so much footage while working on a project. Right now my capture folder is sitting at 128 GB (interesting number) with more from yesterday’s SD Cards waiting for transfer.
So that what I captured does not go to waste, my goal is to re-work the project and produce an AddOhms video out of it.
Best of luck to everyone else. I look forward to watching your build videos and seeing who becomes the next Ben Heck.
  • mayermakes
    mayermakes over 8 years ago +4
    Sorry to hear of your bad luck with the project. I was very eager to see your video. I'm sure it will make a great addOhms episode. Btw I see your 128GB of files and I raise my 256GB of Video files for…
    genebren over 8 years ago +3
    Well, you gave it a good shot. There is a lot to say about having tried and failed. It is a lot better than not having tried at all. There is a lot of evidence of good work in the pictures that you posted…
  • baldengineer
    baldengineer over 8 years ago in reply to jomoenginer +3
    Thank you for the encouraging words Jon. The video is due in the morning. Since I did not achieve the primary requirement, a working build, I cannot participate. As I said above, I plan to recover the…
  • mayermakes
    Btw I see your 128GB of files and I raise my 256GB of Video files for mine...it came down to 18:01min
    To focus on the positive side, with taking more time for your project this project can turn into a very extensive and in depth episode of add ohms with usefull ressources for others.
    Something you just couldn't  do within the given time.
  • baldengineer
    baldengineer over 8 years ago in reply to davedarko
    Thanks Dave. I'm looking forward to your video. I hope you continue to work on the cartridge slot. I do not think you should feel like you failed. There's always the chance for Part 2. image
  • davedarko
    davedarko over 8 years ago
    Glad you still want to publish that video! My cartridge reader -the one key cool thing about my project- doesn't work either and I had to stop working on it yesterday to finish cutting the video. So it feels like failure, too. Learned a lot though and need to do a follow up on the console as well. Man that really is too bad though, I had high hopes for you because of your production quality and you sharing stuff while building!
    Well, you gave it a good shot.  There is a lot to say about having tried and failed.  It is a lot better than not having tried at all. There is a lot of evidence of good work in the pictures that you posted, like that very clean front panel.
    Gene
