John Wiltrout's Blog Attempt to capture sprectrums of LEDs
  • Author Author: jw0752
  • Date Created: 22 Aug 2015 6:27 AM Date Created
  • Views 927 views
  • Comments 12 comments
  • led_spectrum
jw0752
jw0752
22 Aug 2015
Earlier today in a blog post  http://www.element14.com/community/community/design-challenges/vertical-farming/blog/2015/08/16/use-of-leds-in-vertical-farming
I volunteered to try to capture the spectrums of some of the common LEDs. The discussion in that thread had been about the effectiveness of LEDs as grow lights for the Vertical Farming Challenge. I have a cheap spectroscope that I got to show the grandkids about how we can know the elemental composition of things by looking at their spectra. The poor quality of my results made me decide to present the pictures as a separate Blog so that I wouldn't mess up the other discussion . I have reference the other discussion above and I will cross reference this one in that thread.
There were a couple strikes against me from the start as the spectroscope was cheap and my camera was never designed to take pictures in a spectroscope.
Here is a picture of the bright line spectrum of a fluorescent light taking after 20 picture and 2 hours of experiments.
Notice the bright green line at 546 nm. This line is from the Mercury in the fluorescent tube. My hope was to get images like this of the light from different color LEDs but that wasn't to be.
I fell back on plan "B" and used a diffraction grating in front of the different color LEDS and photographed the spectrums created on the grating.
Here is a picture of the spectrum  of a RED LED. In this case I could see no spread outside the Red in the spectrum.
I next chose an Amber colored LED and this time we get a few colors in our spectrum.
Moving on to the Green LED we also see a fairly good spread of color in the spectrum.
The Blue LED had some spread to the longer wave lengths that I could see with my eye but the camera had difficulty capturing them.
Finally I took a picture of a white light LED and got the best spectrum, as we might have expected.
Other than a curiosity this information will be of little help in the Vertical Farm Project. I was surprised that the LEDs that I tried had as much spectral spread as they did. I really expected a much narrower band of light.
    shabaz over 11 years ago +3
    I'm impressed it was able to resolve the amber and green LEDs to quite some detail - more than the datasheet reveals I bet. And examination of your camera image would probably help with intensity measurements…
    shabaz over 11 years ago +2
    Hi John, Wow - this is a really great experiment, and still provides valuable information. Also it shows that sometimes we should try to explore to this level, so that we understand components better.…
    jw0752 over 11 years ago in reply to shabaz +2
    Perhaps I should post it on the UFO Enthusiast website and get everyone excited. The full diffraction grating image of the white light did remind me of some of the HUBBLE images of galaxies.
    I'm impressed it was able to resolve the amber and green LEDs to quite some detail - more than the datasheet reveals I bet. And examination of your camera image would probably help with intensity measurements for example.
    By the way, the second-to-last photo looks like you're trying to create evidence of new UFO sightings!
    balearicdynamics over 11 years ago in reply to jw0752
    Hi John, it is true, but recovering some memory when I was using the first Perkin-Elmer spectroscopes, maybe a test with opaline white glass in front of the source can help to generate a diffuse light reducing the systematic error of the spectroscope sensor without generating too damaging interferences on the light itself. Maybe ?
    Enrico
    Thanks Enrico, Shane and Shabaz,
    After closing the experiment last night and going to bed I lay in the dark staring at the ceiling and had some realizations. First : The colored plastic of the LEDs I was measuring served as filter material and would have attenuated some frequencies much as a band pass filter does in electronics. Second: The spectrums that were photographed on the diffraction grating were uncollimated and as such produced the spectrum with very wide color bands. Sampling light from a point source would have been much better but the limitations of the sensitivity of my camera and the brightness to which I could push the LEDs were barriers to getting good images. I have renewed respect for the scientists who work with spectroscopy and the precision of their measurements that allow then to make good determinations about the composition of light sources.
    Hi John,
    I think the diffraction grating output is pretty good too, considering that anything more needs quite complex hardware, like a smaller entry and collimation.
    As you know, this all gets difficult and time consuming! It is impressive you managed as much as you did in the time you had.
    I tried to create a spectrometer at one stage (and selected a grating, mirrors, CCD, etc) but it has been put on hold indefinitely due to all these difficulties.
    Even the software to model it all is difficult to use, the trial versions were restricted to very few optic elements, and required background knowledge to use which I didn't have - and apparently neither do eye opticians : (
    There are some open source spectrometer projects, but none seemed at a stage ideal to follow. There is a book (I can dig out the title sometime) which had more prescriptive maths and practical guidelines, rather
    than a deep physics textbook style, and I followed that at the time. Most of the amateur astronomy folk are interested in this area, so that is a source of useful, practical information.
