NexGen Flight Simuator NexGen: Tech Tip V. Remove Labels and Adhesives
  • Author Author: phoenixcomm
  • Date Created: 21 Aug 2019 4:49 PM Date Created
  • Views 2401 views
  • Comments 18 comments
  • nexgen
  • tape
  • wd-40
  • label
  • motsenbocker's lift off
  • label remover
  • tech tips
  • and adhesive remover.
  • krudkutter
phoenixcomm
phoenixcomm
21 Aug 2019
Ever try and remove a label from plastic? Yep, WD-40, Goo Gone, and others including yep peanut butter well just don't really work, or damage the plastic that the label is attached to. Most of you have used the old stand by a hair drier as well. But that tends to leave a residue, and you cant use it on PCB boards as its way too hot.image
Well, you got to check this stuff out. Motsenbocker's LIFT OFF Tape, Label, and Adhesive Remover. I have this old Milwaukee too case that had some fool put masking Duck tape on. And I could never get it cleaned up. Squirted a little on the mess and bingo it came off with a scratcher sponge. A little soap and warm water and it looked factory fresh.image
On-line it is about $10, but at Walmart, it is about $6.
UPDATES:
Sorry Fix: not masking tape but Duck Tap!
Added the third and fourth sentences starting with: "Most of you have used the"
    Jan Cumps over 7 years ago +5
    What helps with older labels that have been there for a long time, in particular paper ones: Heat them with a hair drier on a temperature that you normally use to dry your hair. This often makes the glue…
  • colporteur
    colporteur over 7 years ago +4
    OK, I shelled out $ 38.22 Canadian to Amazon on your commentary for 32oz of the label removing elixir. Your pic of the removal products looked like it was taken from the shelf in my garage. I am hoping…
  • colporteur
    colporteur over 6 years ago in reply to phoenixcomm +4
    As I have gotten older or as my patience has gotten shorter, I'm skeptical when I hear the expressions, it's easy or it works. I discover it is easy, if you have a Phd in the subject and it works, provided…
  • phoenixcomm
    phoenixcomm over 7 years ago in reply to jw0752
    jw0752
    You might have to check more that one. But they are in the stores. Just not all of them.
  • phoenixcomm
    phoenixcomm over 7 years ago in reply to Jan Cumps
    Done that too, pain in the ass and there is always some leftover to deal with. And somethings you don't want that much heat on. Put a little of this on a Q-tip let it sit and it's Gone!
  • phoenixcomm
    phoenixcomm over 7 years ago in reply to michaelkellett
    michaelkellett  It does say anything except its patented. sorry.
    try https://desertcart.co.uk/brands/Motsenbocker's%20LIFT%20OFF is said 27GB I don't know how much that is. But check with your Walmart or Amazon as well.
    jw0752 over 7 years ago
    I went to the local Walmart and it seems that it is only available on line.
    Heat them with a hair drier on a temperature that you normally use to dry your hair. This often makes the glue sticky again and then the label can be removed without damaging the area it was put on.
    It sometimes helps to make the glue sticky enough that you can roll it into a gummy ball that's easier to remove.
    • Vote Up +5 Vote Down
