NexGen Flight Simuator Tech Tip VIII: HP 3330 Laserjet Warm Up Issues!
  • Author Author: phoenixcomm
  • Date Created: 15 Mar 2020 11:07 PM Date Created
  • Views 1963 views
  • Comments 10 comments
  • laserjet
  • bulb warm up
  • tech tip
  • fix
  • hp 3330
  • scanner issue
phoenixcomm
phoenixcomm
15 Mar 2020
I have to warn you this fix is not for the faint of heart!
My Hp 3330 laserjet has been pushing paper for me for almost 20 years, without problems aside from every once in awhile changing the toner cartridge.image
About a week ago it would sit there making funny noises a the display stated Scanner Warmup. So I unplugged the printer and plugged it back in with the same results. image Since this is my only B&W printer I had two choices 1)  Buy a new printer (can't afford it), 2) use my Bother Color printer but the Black cartridge was dead! 3) fix the damn thing (hey I can fix jet engines!) So what the hell! When I Googled the problem, I got several hits (videos), and they explained that you don't need to buy anything. It is only the mirrors (in the black thing by the lamp) and they are most likely dirty. So you have to take the whole top apart. Control Panel and shroud, both side covers, and the upper side shrouds as well. This is like a bazillion screws so you will need a good mag tip Phillips screwdriver.
In step 15 you have to remove the plastic cover shown in step 16. There are square holes at each end. Use a pick to press down to release the clip.
Then Q-tips to clean the mirror frames (5), I cleaned them with Windex. But the glass deck was another story, hot water, and Dawn.
When everything was cleaned I put the glass deck in place and plugged it in. Eureka, it bitched about not having any paper in the tray!! image I then unplugged it for the last time and screwed it all back together. It is back where it belongs, on the stand, pushing Paper!!
Here is the video I used as a guide. Sorry, the guide was pulled on YouTube. So here is the blow by blow but no video you have to follow the pretty pictures! If you can't figure out how to reassemble the monster, start at #15 and go to #1.
1image2image3image
4image5image6image
7image8image9image
10image11image12image
13image14image
15image16image17image
    dougw over 6 years ago in reply to Jan Cumps +4
    I save all motors, solenoids, switches, opto-couplers, gears, screws, washers, LEDs, buzzers, bearings, rollers, fans, power cables, fuse holders, heatsinks, magnets, springs (there are lots of springs…
    dougw over 6 years ago +3
    Good job. You are right about the bazillion screws. I took a couple of laser printers apart to salvage whatever was interesting. It definitely increased the number of screws in my miscellaneous screw container…
    Jan Cumps over 6 years ago in reply to dougw +2
    What did you save? The steppers? Also, did it just make your parts stash bigger or were you able to use something?
  • phoenixcomm
    phoenixcomm over 6 years ago in reply to Jan Cumps
    Jan Cumps Save the steppers??? Parts stash???
    It is back online now. back to pushing paper.
    The HP33xx printers could be plugged in via USB, or the Centronics port connector, which makes the scanner moot.
    No, the printer is plugged into my network via an HP JetDirectPlus EX  image
    Good job.
    You are right about the bazillion screws. I took a couple of laser printers apart to salvage whatever was interesting. It definitely increased the number of screws in my miscellaneous screw container. I wouldn't want to put one back together though - that was brave.
  • phoenixcomm
    phoenixcomm over 6 years ago in reply to cstanton
    I have plenty of photos! Don't lose  your nerve! I can be fixed.
    BTW  they are  not my photos!
  • cstanton
    cstanton over 6 years ago
    Awe, the video's gone.
