Feedback and Support
F&S Forum No Activity
200 X-Frame-Options: SAMEORIGIN Content-Security-Policy: frame-ancestors 'self'; X-UA-Compatible: IE=Edge X-XSS-Protection: 1; mode=block X-Content-Type-Options: nosniff X-Telligent-Evolution: 12.x Pragma: no-cache Connection: close Accept-Ranges: bytes Cache-Control: no-store, no-cache, max-age=0 Date: Fri, 02 Jan 2026 11:16:31 GMT ETag: "0x8DE317E31FF1C26" Set-Cookie: .te.csrf=Pi4fdMl412s1F6jPUSRPus6SzzcgRRg6xJsN6LBfWCQ; path=/; secure; SameSite=Lax Set-Cookie: .te.auth=_mkH0RUnekDMu4Uo5t23lbSrkk2P63dLYvunKq4L1%2fv0LI9bNEUsngChPqzFXi8%2btzRtOyJfQpRF3wof9qeep1cC%2bZaeeDQJ%2bbHVrS99CATtsqlxSXzalsSzb2o87X70eqxtGyAaDqzmkaM5aDQVy9O2fpo2HZb3LjRNuGD4Cdm%2bo2GHR5ViSS%2b5194su7IBuvGKStEERuvIC8iD%2bABabAh%2bU75BwBc537sE8GX98t%2bSw9aBKJNxWIqGsXBnVSDIsbXDiBIE0FvVrP4y4jWj15w%3d%3d; path=/; secure; HttpOnly; SameSite=Lax Set-Cookie: e14Guest=1; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14Country=NL; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14Language=en; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14TimeZone=Etc/UTC; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Server-Timing: cdn-cache; desc=MISS Server-Timing: edge; dur=31 Server-Timing: origin; dur=46 Server-Timing: ak_p; desc="1767352591063_34864915_580737524_7649_6597_6_8_-";dur=1 Strict-Transport-Security: max-age=86400 ; includeSubDomains ; preload #set ($UserId = $core_v2_user.Accessing.Id) #set ($Roles = $core_v2_utility.MakeList('Moderators', 'Almost Admins', 'Administrators')) #set ($IsAdminLike = $e14_utils.IsUserInRoleOrAdmin($UserId, $Roles)) #if($IsAdminLike == 'False') #end
  • Locked Locked
  • Replies 23 replies
  • Answers 2 answers
  • Subscribers 20 subscribers
  • Views 1663 views
No Activity
mcb1
mcb1 over 8 years ago
Today when I signed in I was surprised that there was nothing in the Inbox.
I was more surprised when I saw No Activity.
I could see conversations that I should have in my inbox/activity when I logged out ....
Clearing the cache, logging back in, and now a completely new computer and browser has similar results.
Suspecting there is a setting that has changed, I looked at what I was following.
For some unknown reason I'm not following anything.
What Have I done wrong to wipe out everything ?????
Any ideas Dudley
  • Dudley
    Dudley over 8 years ago in reply to Dudley +4 suggested
    We're back online following another outage, this time we lost connection to the image server and the database. The image server is core to every day usage and without it the site can't run. The database…
  • Dudley
    Dudley over 8 years ago in reply to geralds +3 verified
    This is a problem with our activity server. Seems we're having internal network problems, and seems we've been having them on and off over the weekend. It's not the only problem we have either, two of…
  • Dudley
    Dudley over 8 years ago +3
    Yeah, we had another unscheduled outage at that time. Again, internal network was to blame. oadesida was all over it though and got it back up and running, so I had nothing to do when I came in this morning…
  • Dudley
    Dudley over 8 years ago in reply to geralds +2
    Yeah I did, but I thought I'd leave it to Megan. I generally keep half an eye on F&S, I have mail notifications to anything posted to that space so I see everything that gets posted there and read almost…
  • rachaelp
    rachaelp over 8 years ago in reply to Dudley +2
    Dudley Nelson wrote: so I had nothing to do when I came in this morning except reply to this Well if you are twiddling your thumbs there is always the rankings issue to go yell at the vendor about aga…
  • Dudley
    Dudley over 8 years ago in reply to rachaelp +2
    I took the updates on the discussion in TM last night, and already got a vapid "thanks for the update" response from them. I'll go update that thread.
  • Dudley
    Dudley over 8 years ago in reply to fvan +1
    Yeah, that went through my head
  • Dudley
    Dudley over 8 years ago in reply to geralds +1 suggested
    Just want to follow up on this and make sure that nobody has any more site issues? To the best of my knowledge, everything should all be fine now.
  • geralds
    geralds over 8 years ago in reply to Dudley +1
    Hi, Thank you very much for all. Absolut correctly - "Time is busy" - I'm waiting, this is not so important as than i can not work here. Then we can talk about in this other thread where I've posted my…
    mcb1 over 8 years ago in reply to Dudley +1
    Thanks Dudley.
  • jkutzsch
    0 jkutzsch over 8 years ago
    mcb1  I am having the same issue, in fact was just looking to see if anyone else was posting on it.
    Top & Trending
    There isn't any activity yet.
    As soon as people join and begin creating and sharing content, you'll begin seeing activity here. Create something now to get started!
    You don't have anything in your Inbox
  • fvan
    0 fvan over 8 years ago
    Yesterday inbox wouldn't clear, today, it remains empty.
  • rachaelp
    0 rachaelp over 8 years ago
    Yep its definitely broken. It stopped working correctly for me late last night.
  • geralds
    0 geralds over 8 years ago
    Yes, i have the same issue.
    Since yesterday 23h13 CET there are no mails in the inbox.
    Gerald
  • Dudley
    0 Dudley over 8 years ago in reply to geralds
    It's not the only problem we have either, two of the four server nodes are down, which shouldn't cause you any drama, but it causes us problems. And of course, if a third goes down, then it does start causing you major drama.
    And of the two remaining nodes, only one has a connection to the activity engine.
    We're all over this and we're aiming to get normal service back as soon as.
    Thanks geralds - a time window on when things were last normal is really *really* useful image We have the logs, but knowing when things for end users went from normal to not-normal is very useful data!
    I'll try to give you updates, but only if I'm not involved in firefights image
  • geralds
    0 geralds over 8 years ago in reply to Dudley
    Hi Dudley,
    my pleasure.
    Today i postet now in some forums - RoadTest, Eagle-Exchange, Feedback/Support: - posting works, the point - reputation counter works,
    i also received your private email in my local mail server.
    In the element14-inbox there is a name under grayed "Jane Doe", what's that, why?
    The last email what i received was from Randall - 11h12 PM:
    https://www.element14.com/community/groups/roadtest/blog/2017/03/19/why-do-some-roadtest-winners-stop-logging-in?et=blog…
    Best Regards,
    Gerald
  • fvan
    0 fvan over 8 years ago in reply to Dudley
    Ah ... Mondays ... image
  • fvan
    0 fvan over 8 years ago in reply to geralds
    That's just a dummy name as an example to show you where to type a user name to filter on.
  • geralds
    0 geralds over 8 years ago in reply to fvan
    ok, thanks. I thought this but i was unsure.
    Gerald
  • Dudley
    0 Dudley over 8 years ago in reply to fvan
    Yeah, that went through my head image
  • Dudley
    0 Dudley over 8 years ago in reply to Dudley
    We're back online following another outage, this time we lost connection to the image server and the database. The image server is core to every day usage and without it the site can't run. The database even more so!
    We've bounced the entire stack this time. Hopefully that should sort things out. If not, we've really reached the end of where "have you tried turning it off and on again" can take us.
    We also have mobilized a small army of server gnomes to look over the OS and database logs to see if we can get to the bottom of what caused it. And I'm posting this while copying the application logs down to my local machine to see if I can see what went wrong at the start of the latest outage. The database is my suspicion based on what I've seen, but that's a guess at this stage.
    As fvan says, who needs Mondays!
