    • Avnet Boards Community
Feedback and Support
Site Announcements and Status Resolved: You May be asked to Register/Login when Downloading an eBook
200 X-Frame-Options: SAMEORIGIN Content-Security-Policy: frame-ancestors 'self'; X-UA-Compatible: IE=Edge X-XSS-Protection: 1; mode=block X-Content-Type-Options: nosniff X-Telligent-Evolution: 12.x Pragma: no-cache Connection: close Accept-Ranges: bytes Cache-Control: no-store, no-cache, max-age=0 Date: Fri, 12 Sep 2025 04:20:36 GMT ETag: "0x8DDA27811105BA2" Set-Cookie: .te.csrf=Pmc98fGq33ty3xUa6MXbkS_3P3Zut4fgfFxKCwFRFfE; path=/; secure; SameSite=Lax Set-Cookie: .te.auth=_IC7L0wREJIQ%2fnhvGJX7h2u99vVskkPgNE6CTVD9c2JWNvgn70GCuKqeaFo1di4%2b6%2faV7HkkrOn6v3urL%2bvSAXiBqXfGVi4EBr8g5639ISsyURPjWdbPS59%2fm30qnatDc5PE%2bf%2bkc6fsU%2fknycQHEkg6boG%2fbWIRae1%2bev16FYtOuvT%2fiaLmh3AByQSaN1K%2fcgsuqz7XX%2bltCm3g9Gmd29WkoDVHKlWv%2bXNv9H2PmyJnsfXXbulIPGaSiRTLXgpGhdNjSLcoAw94X2UKB5hY%2brA%3d%3d; path=/; secure; HttpOnly; SameSite=Lax Set-Cookie: e14Guest=1; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14Country=NL; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14Language=en; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14TimeZone=Etc/UTC; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Server-Timing: cdn-cache; desc=MISS Server-Timing: edge; dur=25 Server-Timing: origin; dur=42 Server-Timing: ak_p; desc="1757650836346_34604952_755983491_6655_5669_3_10_-";dur=1 Strict-Transport-Security: max-age=86400 ; includeSubDomains ; preload #set ($UserId = $core_v2_user.Accessing.Id) #set ($Roles = $core_v2_utility.MakeList('Moderators', 'Almost Admins', 'Administrators')) #set ($IsAdminLike = $e14_utils.IsUserInRoleOrAdmin($UserId, $Roles)) #if($IsAdminLike == 'False') #end
  • Subscribers 2 subscribers
  • Views 447 views
  • ebook
cstanton
cstanton over 2 years ago
There's a known problem being investigated by the development team that when you attempt to download an eBook you may be requested to login even though you're already logged in, or you may be asked to register again to download the eBook.
While you should be asked to confirm your details, and these should be automatically populated, you shouldn't be requested to re-register or re-login to download an eBook.
The development team are currently investigating this and there's currently not a timeline for a fix.
