Arduino
Arduino
Blog how to use multiple buttons with arduino???????
  • Author Author: nmmbeginer
  • Date Created: 1 Mar 2015 10:23 PM Date Created
  • Views 5717 views
  • Comments 14 comments
  • help
  • button
nmmbeginer
nmmbeginer
1 Mar 2015
ok so i am new to arduino. i am trying to have one button turn on the led witch is in pin 13 and another button to turn it off but im having problems. when i press the button it turns on when i let off the button it goes off.  here is my code so far.
const int buttonPin = 2;     // the number of the pushbutton pin
const int ledPin =  13;      // the number of the LED pin
const int buttonPin1 = 3;
// variables will change:
int buttonState = 0;         // variable for reading the pushbutton status
void setup() {
  // initialize the LED pin as an output:
  pinMode(ledPin, OUTPUT);
  // initialize the pushbutton pin as an input:
  pinMode(buttonPin, INPUT);
  pinMode(buttonPin1, INPUT);
void loop(){
  // read the state of the pushbutton value:
  buttonState = digitalRead(buttonPin);
   buttonState = digitalRead(buttonPin1);
  // check if the pushbutton is pressed.
  // if it is, the buttonState is HIGH:
  if (buttonState == HIGH) {
    // turn LED on:
    digitalWrite(ledPin, HIGH);
    delay(100);  // Wait 0.5 seconds before re-checking button states
    // turn LED on:
    digitalWrite(ledPin, LOW);
if some one can tell me what im doing wrong please tell me.i just started programming and i dont know much i can read and under stand code but i am not good at writing code.
  • gadget.iom
    gadget.iom over 11 years ago in reply to nmmbeginer +4
    The following variables define the physical pin each button is connected to: const int buttonPin = 2; const int buttonPin1 = 3; In this case you've essentially names the switch connected to pin 2 'buttonPin…
  • clem57
    clem57 over 11 years ago in reply to nmmbeginer +2
    nmmbeginer I would suggest to take code you had working for one LED and duplicate it with each variable changed to a new one like LED to LED2 etc. The logic is the same, but need there own set of variables…
  • nmmbeginer
    nmmbeginer over 11 years ago in reply to gadget.iom +2
    so when i posted this post i knew almost next to nuthen about arduino and how to program it. basically i was trying to do something that was way over my head. so i went and watched a bunch of beginner…
  • nmmbeginer
    nmmbeginer over 11 years ago in reply to clem57
    thanks for all ur help i got it working. now lets say i want to do 2 thing. for example button 1 turns the led1 on and off but button 2 turns led2 on and off how do i identify the buttons
  • clem57
    after testing button for a press
  • nmmbeginer
    ok so i see how this would work but where do i put the    LEDState^=1
  • clem57
    First you really need only 1 button! Add a variable that remembers whether LED is on/off. When buttonState is HIGH then change LED state by flipping the bit with XOR:
    int LEDState  = 0; // Put this up top
    // flip it
    LEDState ^= 1;
    Change LED with
    digitalWrite(ledPin, LEDState);  // 0 for off and 1 for on!
