Arduino
Arduino
Blog Why does it work...sometimes?
  • Author Author: colporteur
  • Date Created: 9 Jul 2022 2:58 PM Date Created
  • Views 2270 views
  • Comments 8 comments
  • arduino-troublshooting
  • arduino_development
colporteur
colporteur
9 Jul 2022
Why does this code loaded on a Nano knockoff work sometimes, if I clearly missed a section of code?
int LEDPin = 9;
int ButtonPin = 8;
int RelayPin = 2;
void setup() {
// initialize digital pin LED_BUILTIN as an output.
pinMode(LEDPin, OUTPUT);
pinMode(ButtonPin, INPUT); //Set the switch's pin to be an input with a pullup (default is HIGH)
pinMode(RelayPin, OUTPUT);
digitalWrite(RelayPin, HIGH);
I wrote some Arduino code to control a relay when a button is pressed. It worked on the bench at home but in the lab it didn't work. Two different breadboard circuits same Nano. The issue was I failed to pinMode the OUTPUT to the relay shown in red.
My question to the aficionados of Arduino, those individuals with much more knowledge and experience with Arduinos than moi, is why did it work? Uploading and compiling the code produced no warnings. At least none that I have become accustome to making. On one breadboard layout, the circuit worked but on another breadboard layout, it did not. I sheepishly confess it took me a few cycles to figure out what I had done wrong. This required multiple trips between the lab and home so I know it wasn't just a freak one-time event.
Any insight you can share loads up my toolkit for the next time.
  • colporteur
    colporteur over 4 years ago in reply to Jan Cumps
    The pin is floating (undetermined) if not set, agree. Thanks for the c++ insight. Why would the undetermined on one setup be HIGH and on another it would be LOW?
    The setup that was low was consistently low. On the setup that was high, was consistently high.  I assume the undetermined it is impacted by supply voltage?
  • ralphjy
    ralphjy over 4 years ago
    I would guess that your two breadboard circuits are not hooked up identically.  Are the other components on the breadboards besides the Nano the same?  What Nano knockoff are you using?  I think Jan's suggestion of measuring voltages will lead you to the cause.
    Jan Cumps over 4 years ago
    The compiler did not show an error because you made no c++ syntax error.
    For the ATMxxx type of Arduinos, if you don't set PIN mode, they are high-Z, floating. Undetermined.
    If you still havethe working and non-working setups, put a volt meter on the pin and check if you measure a difference ...
