Arduino Forum Have a question about Arduino? Ask me!
  • Replies 1914 replies
  • Subscribers 527 subscribers
  • Views 69798 views
  • jeremy_blum
  • expert
  • student
sciguy14
sciguy14 over 15 years ago
This thread has been closed to new questions.
However, we welcome you to Post Your Questionabout Arduino in the element14 Community Arduino group.  You'll find many fellow members and experts who have just the answer you're looking to find!
Thank You, Your Friends at element14 Community
Jeremy Blum
Jeremy is an Electrical and Computer Engineering Student at Cornell University. He has been building microcontroller projects since high school, from a prototype prosthetic hand with a novel control scheme, to a nerf gun that fires at the intruders and uploads their picture to the web.
  • billabott
    billabott over 13 years ago in reply to e14 Contributor +2
    @Brendan Your video is somewhat adequate for the intended purpose, however, from an engineer's point of view it is lacking in providing pertinent facts. Such as the part number, data sheet, and source…
    e14 Contributor over 15 years ago +1
    Jeremy, thanks for your intro videos. I am just getting started myself in Arduino though I have done some simple electronics projects using Atmel chips. Here is an example using ATTiny13 chips. www.youtube…
    Hi Jeremy I've built a device (see picture) with an Arduino and Ethernet shield that connects to our Network Monitor (Nagios) and moves an arrow to indicate if any of the computers we monitor are not responding…
  • sciguy14
    sciguy14 over 15 years ago in reply to e14 Contributor
    Terry,
    Please try to start it yourself.   Then post it up here when you run into problems and we can try to help.
    Hi Jerry, I have an Invention. Do you create prototypes? If so do you have a personal e-mail address so I can provide you with more information.
    Hello experts,
    I want to use a coin cell to power a circuit and am planning on using a simple metal battery clip to attach the battery to the PCB.
    The question is how to best create the part in Eagle. I could create a pad, but that's limited in size. I'm concerned that I need to stop the solder mask over the region to avoid the battery sitting above the pad. I'd also need to avoid signal lines under the clip.
    Is there a standard way to do this?
  • sciguy14
    I do not create prototypes for other's projects at this time.  Sorry.
  • sciguy14
    Ladyada's EagleCad Library contains a coincell footprint: http://www.ladyada.net/library/pcb/eaglelibrary.html
    It will work with this: http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail?name=3000K-ND
    e14 Contributor over 15 years ago in reply to sciguy14
    I intended to send the question to Richard since it was an Eagle/PCB question, but I clicked the wrong item. Limor's example shows exactly what I needed for the pads.
    My hackerspace is making an open hardware "digital domino" for Maker Faire and we need to get the board run sent out.
    Thanks for the help Jeremy.
    Hi  i need to build  some kind of costum keyboard or joystick, the arduino borard can helpme whith that? i need a combination of entris from pulse switch, thoggle switch, and rotarys
    i´m a totaly new to programin and i looking for something not too hard to learn
    thanks
    I constructed the following circuit, using the accompanying code:
    http://itp.nyu.edu/physcomp/sensors/Reports/PIRMotionSensor
    The sensor triggers every few seconds, as seen in this serial output:
    1023
    1023
    1023
    1023
    18
    1023
    1023
    18
    17
    18
    17
    1023
    1023
    1023
    1023
    1023
    1023
    The sensor is in a closed, motionless cardboard box. When I disconnect the sensor, the false alarms stop.
    Why is the sensor triggering, and how do I stop it?
    Sincerely,
    T.
  • sciguy14
    Yes, the arduino would work well for this.  This shield should be a good place to get you started: http://www.sparkfun.com/products/10115
  • sciguy14
    I'm honestly not sure why it would false trigger - it's a pretty simple circuit.  What happens if you cover it completely by putting a board in front of it?  It's possible that IR light from other sources in th room is triggering the sensor.
