Arduino Forum Tattoo machine controller?
  • Replies 13 replies
  • Subscribers 418 subscribers
  • Views 5351 views
Is it possible to create a tattoo machine controller with arduino?  Tattoo machines usually work between 5-13vdc at less than 1 amp.  Right now most machines operate by opening and closing a circuit containing two electromagnets to pull the armature bar down (pushing the needle down) then breaking the circuit, releasing the needle/bar.
I'd be interested in creating something to either draw it's current from a deep cycle marine 12v allowing me to adjust the voltage or more preferably, something that would allow me to take either 120vac or 12vdc and convert it to an appropriate voltage that would allow me to turn on and off the electromagnetic coils using the arduino.
    e14 Contributor over 14 years ago in reply to e14 Contributor +1
    After some thinking last night i thought of a way to make the machine more digital. An arduino is along the right line of thinking but isn't powerful enough for the job. What you will want to do is rewire…
  • YT2095
    YT2095 over 14 years ago +1
    personally I`m not entirely certain why you would need an arduino for this at all? if I wanted such a machine, I would use (as stated above) an LM317 feeding the base of a 2n3055 transistor giving you…
    e14 Contributor over 14 years ago in reply to billabott +1
    Google translate doesn't do Geek > Noob yet...
    Take a look at this - you can control your machine electronically by adjusting(and saving) the duty cycle and frequency independently, without adjusting the voltage. Several settings for one machine without adjusting the contact screw either.
    www.infinity-tattoo.com
    G. Forrest Cook published a circuit to simply control Frequency and duty cycle in 1997. So, this isn't necessarily the news inspite of  your commercial asperations.
  • sheedstaa
    sheedstaa over 5 years ago
    Purchase a $7 voltage drop module from wish.com.
    0 - 40v IN, 0-32V OUT @ 6W, inc short circuit protection.
    This is the simplest, cheapest method that should suit your purpose.
    You will also require a transformer to drop from 220 AC to 0-40v DC output. Adjusted with a simple screw on all types.
    This example is one of many available. image
