    • Avnet Boards Community
Arduino Forum A couple of Arduino libraries I wrote, AS3935 lightning detector and TCS3471 color/light sensor
  • Replies 36 replies
  • Subscribers 393 subscribers
  • Views 3658 views
  • sensors
  • prototyping
A bit of a shameless self-promotion image I wrote two libraries for two interesting sensor chips, first is AS3935 lightning detector chip, that can warn you about coming storm while it is still 40 kilometers away and the second in high dinamic range 16bit resolution color and light sensor chip TCS34717. Both libraries in my opinion are interesting in the way communications are implemented, library code does not access any other library, like SPI or Wire, directly, but rather relies on user sketch to provide functions to communicate over SPI or i2c bus, which makes them usable with almost any imaginable setup and scenario.
Both libraries can be downloaded from my github - https://github.com/raivisr?tab=repositories
And break-outs if anyone is interested in these, can be purchased here - https://www.tindie.com/shops/TAUTIC
    Former Member over 11 years ago in reply to Former Member
    Thank you for the library.
    Of course it compiles and such but it (the example code) complains that the tuning is out of range.
    Tried it with an arduino uno and a pro mini. Also tried 3,3V instead of 5V.
    The bestdiff value it finds during calibrate is 3125.
    Any ideas?
    Let me guess, you have Embedded Adventures breakout?
    Indeed I do.
    They require anything special?
    I have two of them in fact and both fail. Both in i2c and spi.
    I get a lot of support requests because of those breakouts and I have no idea if that is because they are only ones left who make them or if that is because those guys do something wrong, like use not so high quality caps in tank circuit. Since they seem to refer people to me for support, I kindly asked them to send me one of their modules, but got no reply whatsoever.
    Anyway, a few days ago I wrote instructions on how to connect to UNO R3, untested, because I neither have Uno, nor breakout by Embedded Adventures:
    module
    Uno r3
    VCC
    5V
    CS
    10 SS
    IRQ
    2
    SCL
    13 SCK
    MISO
    12 MISO
    MOSI
    11 MOSI
    GND
    GND
    Open example sketch and comment out the line
    attachInterrupt(1,AS3935Irq,RISING);
    and uncomment line
    // attachInterrupt(0,AS3935Irq,RISING);
    at the end of setup() function.
    If you still get that dreaded tuning error, make sure your wires are short and module is away from EMI sources (especially ones that are susceptible to be around 500kHz) during tuning. After tuning sample sketch prints some register values, if all of those are zeros then most likely there is something wrong with SPI comms.
    My library does not support I2C, but there is a fork on github that is modified for that - https://github.com/SloMusti/AS3935-Arduino-Library
    If you like I can buy you one?
    If so, please contact me at mail@vanheusden.com
    In the mean time I'll give your suggestion a try tonight.
    Note that I also attached such a device to a raspberry pi. It communicates with the rpi but does not detect any lightnings. Well unless none did strike in the last 10 days, that's also possible I guess.
    regards
    Thanks, but no thanks image I could buy one myself if I wanted, but I don't, too much of different stuff piling up and gathering dust as it is, besides, I wrote the library as a courtesy to my friend Jayson of TAUTIC Electronics, who made first breakouts of this chip and I had never had real interest in detecting lightnings.
    embeddedadventures replied to my e-mail and promised to send me one of their lightning breakouts, so hopefully I will be able to answer Embedded Adventures AS3935 breakout related questions better. I might add i2c support into library as well.
    Former Member over 10 years ago in reply to Former Member
    Downloaded the library, and made the "adjustments'' to the code to operate with UNO. I connected the sensor to my UNO, and was stuck at "Noise floor" message, with a clearly non responsive sensor. Changed noise Floor settings from 0-7, but still no go (also followed other suggestions you made). Ordered 4 Tautic boards, (arrived yesterday), noise floor message still appears - but the sensor responds to disrupters (such as every time I operate my barbeque lighter)  thus I would expect lightning to trigger the sensor! It's a very nice and easy to use library you have written - I almost feel lazy, as it makes using the sensor "too easy". I live in far north Queensland, and storm season is imminent. Will roll out 4 sensors in various locations, and process the information via the internet, and my Arduino Mega GSM project. Thanks again for a great library, and clear instructions to get started. I will post updates on my project when completed, and after some storms have been detected. My expectations are realistic, I do not expect to detect every strike - but to simply have the sensor detect the storm, and give some guidance of strike numbers and distance.
    Thanks for the kind words and good luck with your project image
    almost half a year later promise is still just a promise, so everyone having embeddedadventures breakout are on their own.
