Arduino Forum Arduino Wave Shield
  • Replies 14 replies
  • Answers 7 answers
  • Subscribers 415 subscribers
  • Views 2746 views
  • ardunio
  • motion detection
Arduino Wave Shield
beagles
beagles over 8 years ago
Hi All,
I have an idea for a project and it would be great to get some advice and tips.
The idea started out as a project for my newly purchased Raspberry Pi zero but the more the idea developed the more I found myself going back to my very basic knowledge of the arduino.
I want to make a movement activated, pre recorded voice.
I have purchased the ardunio wave shield for the sound bit and I have a very basic motion sensor and a speaker.
I also bought a mic but discussing with a friend they suggested to pre-record my message using my laptop microphone and then transfer it over to the shield.
What do people think?
Have I gone down the right path for the project I want to build?
Is this project a bit too complex for a novice?
If you have any links to youtube videos etc please comment below!
The first mission of mine is to learn how to solder as the wave shield isn't pre made.
Kaylee :-)
    dougw over 8 years ago +2 suggested
    I recently connected a $2 mp3 player module to a PSoC microcontroller to play recorded audio when a button is pushed. An arduino would work just as well - the micro doesn't have much work to do. It might…
    genebren over 8 years ago +1 suggested
    Hi Kaylee, This sounds like a great learning project. The motion detector should most likely have a high/low level output detecting motion. Use this change to trigger the playing of the wave file. I like…
    DAB over 8 years ago +1 suggested
    Hi Kaylee, If you have some basic Arduino experience, you should be able to accomplish your goal. Check with the RPi website, there are a number of similar projects to yours, so you can read about how…
    0 dougw over 8 years ago in reply to beagles
    That blog is all there is right now. If there is something you would like to see, mention it in the comments under the blog and I will try to address it.
  • beagles
    0 beagles over 8 years ago in reply to BigG
    Hi BigG,
    I've recorded my message and converted it to a wave file using an online converter.
    I could only get it to 22050KHz you think it will work?
    Any ideas on SD card format? I have a format program already downloaded from setting up the raspberry Pi so just need to work out the correct format.
    Thanks again for all your help
    Kaylee
    Kaylee
  • beacon_dave
    0 beacon_dave over 8 years ago in reply to beagles
    The Adafruit library supports FAT16 and FAT32 formats according to this:
    https://learn.adafruit.com/adafruit-wave-shield-audio-shield-for-arduino/sd-card
  • beagles
    0 beagles over 8 years ago in reply to beacon_dave
    Thank you!
