Arduino Forum Serial monitor behaves differently on Windows vs Mac
  • Replies 11 replies
  • Answers 2 answers
  • Subscribers 417 subscribers
  • Views 1549 views
kjhart0133
kjhart0133 over 13 years ago
A sketch I wrote recently uses Serial.write to display the value read from a potentiometer.  This sketch worked fine on my Mac and displayed correct values on the serial monitor.  When I loaded the exact same sketch onto a Windows platform, instead of displaying the numerical value from the pot, I got ASCII characters.
I have limited access to the Windows machine (I'm teaching a group of fifth graders how to use the Arduino) and haven't been able to spend a lot of time debugging this issue.  Any hints would be appreciated.
Kevin H.
  • kjhart0133
    kjhart0133 over 13 years ago in reply to ntewinkel +1
    Nico, I loaded up CoolTerm on my Mac and it works fine. Thanks for the pointer. It's much nicer than the default terminal window that comes with the Arduine IDE (Shift-Cmd-M). CoolTerm doesn't disappear…
  • kjhart0133
    0 kjhart0133 over 13 years ago in reply to ntewinkel
    Nico,
    I loaded up CoolTerm on my Mac and it works fine.  Thanks for the pointer.  It's much nicer than the default terminal window that comes with the Arduine IDE (Shift-Cmd-M).  CoolTerm doesn't disappear when I upload to the Arduino, but you do need to "disconnect" it before you can upload a sketch, and then "connect" back up once the sketch is finished uploading.  I suppose this is just the way it has to be.  Not a big deal.
    Thanks again to Nico and Billabott for all the fine responses.
    Kevin H.
