Arduino Forum Ethernet Shield error
  • Replies 19 replies
  • Subscribers 417 subscribers
  • Views 3424 views
I am using below Open source Code to test my Ethernet sheild connected to Uno . Seems Everything is fine  but when I try to compile or upload its comming up with error ; 'Ethernet has not been declared' and There are few other error probally causing because of the Main error ;
rbbb_server:11: error: 'Ethernet' has not been declared
rbbb_server:12: error: 'BufferFiller' does not name a type
rbbb_server.ino: In function 'void setup()':
rbbb_server:15: error: 'ether' was not declared in this scope
rbbb_server:15: error: 'Ethernet' has not been declared
rbbb_server:17: error: 'ether' was not declared in this scope
rbbb_server.ino: In function 'word homePage()':
rbbb_server:25: error: 'bfill' was not declared in this scope
rbbb_server:25: error: 'ether' was not declared in this scope
rbbb_server.ino: In function 'void loop()':
rbbb_server:39: error: 'ether' was not declared in this scope.
if someone can help me fix this issues it will be grateful Thank you
// This is a demo of the RBBB running as webserver with the Ether Card
// 2010-05-28 <jc@wippler.nl> http://opensource.org/licenses/mit-license.php
//#include <Ethernet.h>
#include <EtherCard.h>
// ethernet interface mac address, must be unique on the LAN
static byte mymac[] = { 0x74,0x69,0x69,0x2D,0x30,0x31 };
static byte myip[] = { 192,168,1,203 };
byte Ethernet::buffer[500];
BufferFiller bfill;
void setup () {
  if (ether.begin(sizeof Ethernet::buffer, mymac) == 0)
    Serial.println( "Failed to access Ethernet controller");
  ether.staticSetup(myip);
static word homePage() {
  long t = millis() / 1000;
  word h = t / 3600;
  byte m = (t / 60) % 60;
  byte s = t % 60;
  bfill = ether.tcpOffset();
  bfill.emit_p(PSTR(
    "HTTP/1.0 200 OK\r\n"
    "Content-Type: text/html\r\n"
    "Pragma: no-cache\r\n"
    "\r\n"
    "<meta http-equiv='refresh' content='1'/>"
    "<title>RBBB server</title>"
    "<h1>$D$D:$D$D:$D$D</h1>"),
      h/10, h%10, m/10, m%10, s/10, s%10);
  return bfill.position();
void loop () {
  word len = ether.packetReceive();
  word pos = ether.packetLoop(len);
  if (pos)  // check if valid tcp data is received
    ether.httpServerReply(homePage()); // send web page data
    0 e14 Contributor over 12 years ago in reply to Robert Peter Oakes
    at below The Code with LCD interface which doesnt work
    // DHT code from:
    // Example testing sketch for various DHT humidity/temperature sensors
    // Written by ladyada, public domain
    #include "DHT.h"
    #define DHTPIN 2     // what pin we're connected to
    // Uncomment whatever type you're using!
    #define DHTTYPE DHT11   // DHT 11
    // #define DHTTYPE DHT22   // DHT 22  (AM2302)
    //#define DHTTYPE DHT21   // DHT 21 (AM2301)
    DHT dht(DHTPIN, DHTTYPE);
    // LCD
    // LCD RS=3, EN=4, DS4=5, DS5=6, DS6=7, DS7=8
    #include Humidity: $D %
      t, h);
    // The main loop
    //  We add to the timer and read the DHT11 values when Timer == 1, otherwise we loop without reading it
    // Once the Timer value == to 1100 we zero it and start the count again.  This way the sensors are only
    // read once every 1100 loops.  Every time we go through the loop we listen for a request on the Ethernet
    //  If we see one we send the webpage.  We also add an animation on the LCD so we know the loop is working.
    void loop () {
      Timer  = Timer+1;
      if(Timer==1)
        ReadDHT11();
        // set the cursor to (0,0):
        lcd.setCursor(0, 0);
        // print from 0 to 9:
        lcd.print("Temp: ");
        lcd.print(t);
        lcd.print("C");
        // set the cursor to (16,1):
        lcd.setCursor(0,1);
        lcd.print("Humidity: ");
        lcd.print(h);
        lcd.print("%");
        if(Animation==0)
          lcd.print("  *");
        if(Animation==1)
          lcd.print("  +");
        Animation = Animation + 1;
        if(Animation==2)
          Animation=0;
      if(Timer==1100)
        Timer=0;
        ReadDHT11();
    This is the code below you suggested but need to add LCD code bit ! I have no qlue what to do .. I am kind of Stuck!  ( I am using It with Wiznet Based Ethernet Sheild)
    #include ");
    • Main Loop
    void loop()
    // listen for incoming clients
      EthernetClient client = server.available();
      if (client) {
        Serial.println("new client");
        // an http request ends with a blank line
        boolean currentLineIsBlank = true;
        while (client.connected()) {
          if (client.available()) {
            char c = client.read();
            Serial.write(c);
            // if you've gotten to the end of the line (received a newline
            // character) and the line is blank, the http request has ended,
            // so you can send a reply
            if (c == '\n' && currentLineIsBlank) {
              // send a standard http response header
              client.print(headerHTML);
              // now send the stuff we want
              client.print(TimeElapsed()); // your old code here
              // do some more stuff
              sendTempToNetwork(client);
              sendAnalogToNetwork(client);
               // were done sending so now send the footer to close the page
              client.println(footerHTML);
              break;
            if (c == '\n') {
              // you're starting a new line
            else if (c != '\r') {
              // you've gotten a character on the current line
              currentLineIsBlank = false;
        // give the web browser time to receive the data
        delay(1);
        // close the connection:
        client.stop();
        Serial.println("client disconnected");
    delay(2000);
    void Cal_Temp()
      if (TempHi&0x80)    // If bit7 of the TempHi is HIGH then the temperature is negative
        P_N = 0;
      else    // Else the temperature is positive
      P_N = 1;
      TempHi = TempHi & 0x7F;   // Remove sign
      TempLo = TempLo & 0xF0;   // Filter out last nibble
      TempLo = TempLo >>4; // Shift right 4 times
      Decimal = TempLo;
      Decimal = Decimal * 625;  // Each bit = 0.0625 degree C
      combined_temp_C= TempHi + TempLo*.0625;
      combined_temp_F = combined_temp_C*1.8+32;
       sprintf(strTempC, "%f", combined_temp_C);
       sprintf(strTempF, "%f", combined_temp_F);
    ////Celsius to Kelvin conversion
    //double Kelvin(double celsius)
    //        return celsius + 273.15;
    // dewPoint function NOAA
    // reference: http://wahiduddin.net/calc/density_algorithms.htm
    double dewPoint(double celsius, double humidity)
            double A0= 373.15/(273.15 + celsius);
            double SUM = -7.90298 * (A0-1);
            SUM += 5.02808 * log10(A0);
            SUM += -1.3816e-7 * (pow(10, (11.344*(1-1/A0)))-1) ;
            SUM += 8.1328e-3 * (pow(10,(-3.49149*(A0-1)))-1) ;
            SUM += log10(1013.246);
            double VP = pow(10, SUM-3) * humidity;
            double T = log(VP/0.61078);   // temp var
            return (241.88 * T) / (17.558-T);
    // delta max = 0.6544 wrt dewPoint()
    // 5x faster than dewPoint()
    // reference: http://en.wikipedia.org/wiki/Dew_point
    double dewPointFast(double celsius, double humidity)
            double a = 17.271;
            double b = 237.7;
            double temp = (a * celsius) / (b + celsius) + log(humidity/100);
            double Td = (b * temp) / (a - temp);
            return Td;
    Thank you
    Regards
    Ankit Patel
    How DO I Add DHT11 library .. I tried Changing DHT22 to DHT11 in source code But it doesnt work. its comming up with error saying ;
    'dht' does not name type
    DCT22_test:7: error: 'dht' does not name a type
    DCT22_test.ino: In function 'void sendTempToNetwork(EthernetClient)':
    DCT22_test:62: error: 'DHT' was not declared in this scope
    I am trying to use DHT11 in same code above !
    Thank you
  • Robert Peter Oakes
    0 Robert Peter Oakes over 12 years ago in reply to e14 Contributor
    Before i dive into that, did the code I sent to you work OK ?
    Peter
    As for DHT22 vs DHT11 the only change is this
        int chk = DHT.read22(DHT22_PIN); change to     int chk = DHT.read11(DHT22_PIN); assuming the DHT11 is on the same pin as the variable DHT22_PIN is configured for which in the code is pin 2
    ?Dear Sir,
    It did. Just need to add LCD part now. Really impressive I had no qlue thought it won't work . but it did.
    Thank you
    Regards
    Ankit Patel
    link in the LCD your using, maybe a link to the product page, there are so many I want to ensure I am helping with the right one
    Peter
    ?Dear Sir ,
    I am using OLED 2x16 yellow 84x44 (Product Code N07QQ)
    Here is the Link ; http://www.maplin.co.uk/p/oled-2x16-yellow-character-display-n07qq
    OLED 2x16 Yellow Character Display | Maplin
    Colour Organic Light Emitting Display with alphanumeric characters. OLEDs remove the requirement for back lit panels and offer vibrant, sharp colours. Low power cons
    Read more...<http://www.maplin.co.uk/p/oled-2x16-yellow-character-display-n07qq>
    Thank you
    Regards
    Ankit Patel
    Sir,
    The Help I am receiving from you sir. I really appreciate it.
    Thank you
    Regards
    Ankit Patel
