Arduino Forum Arduino lcd button input help
  • Replies 16 replies
  • Answers 2 answers
  • Subscribers 418 subscribers
  • Views 2573 views
  • help
  • asap
  • beginner
I am working on a project and i'm trying to get the lcd to print what button was pressed, but it does not respond to the buttons I am going off of my "Arduino Projects Book" so that may be why the code is a bit messy.
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
const int buttonOne = 8;
const int buttonTwo = 7;
int prevSwitchState = 0;
int switchState = 0;
int prevSwitchStateTwo = 0;
int switchStateTwo = 0;
void setup(){
  lcd.begin(16, 2);
pinMode(buttonOne &&  buttonTwo, INPUT);
   lcd.print("Welcome");
lcd.setCursor(0,1);
  lcd.print("Lftbtn = A");
  delay (5000);
lcd.clear();//Clears screen
lcd.print("Rgtbtn = B");
  delay (5000);
lcd.clear();
void loop(){
  lcd.setCursor(0,0);
   lcd.print("test");
switchState = digitalRead(buttonOne);
if (prevSwitchState != switchState){
if (buttonOne == HIGH){    lcd.print("B");
else if ( prevSwitchStateTwo != switchStateTwo){
  if (buttonTwo == HIGH){
lcd.print("A");
  • Robert Peter Oakes
    0 Robert Peter Oakes over 12 years ago in reply to mcb1
    sorry mark, just tried what I had posted and it is in the loop, it is badly formatted so I re-aligned the braces below, both versions compile ok
    peter
    #include LiquidCrystal
    void setup(){
      lcd.begin(16, 2);
      pinMode(buttonOne, INPUT);
      pinMode(buttonTwo, INPUT);
      lcd.setCursor(0,1);
      delay (5000);
      delay (5000);
      lcd.clear();
    void loop()
       lcd.setCursor(0,0);
             lcd.print("B");
      switchStateTwo = digitalRead(buttonTwo);
      if (prevSwitchStateTwo != switchStateTwo )
          if (buttonTwo== HIGH)
             lcd.print("A");
    there is a missing bit where the previous state is not being set for each button though so even if this worked for one press it would not continue but as the previous state is initialized to a zero it should repeatedly write the value when the button is pressed and you may not notice this in reality though it is bad practice
    code should be more like this (Only one switch logic shown here, you need to add to the other one)
             lcd.print("A");
    prevSwitchStateTwo =  switchStateTwo;
    Thanks! It is now working fine.
    0 mcb1 over 12 years ago in reply to e14 Contributor
    Peter is right about using the 'State' to do checking, however initially getting your buttons working was the aim.
    There are some other bits to counter bounce of the buttons, without using delay(), but I'm sure you aren't interested in two buttons displaying A or B in your final project.
    There are are several examples under Examples - LiquidCyrstal that give you some other stuff.
    I also have an example of scrolling a number of characters only, which I should send to Peter to include in his blogs.
    mark
    please do, thanks
    0 e14 Contributor over 12 years ago in reply to mcb1
    I do plan on adding more buttons and the examples in "LiquidCrystal" will be very helpful, thanks again guys!
