Arduino Forum Sensor to detect Human Presence
  • Replies 81 replies
  • Answers 34 answers
  • Subscribers 442 subscribers
  • Views 16819 views
  • human
  • detection
  • internet_of_things
  • sensor
gunaseelan
gunaseelan over 12 years ago
Hello Friends,
                    Is there any sensor to detect human presence . Am aware of PIR (Passive Infra Red) sensor , which would human motion but not the human presence . Another way is by using image processing technique. Kindly suggest me a better solution image .
Thanks.
    e14 Contributor over 12 years ago +7 suggested
    Hi Gunaseelan, OMRON do a thermal sensor that can detect stationary thermal objects as opposed to standard PIR motion sensor that only detect motion. The OMRON D6T thermal sensor is able to detect the…
  • beacon_dave
    beacon_dave over 8 years ago in reply to shabaz +6 suggested
    shabaz Voight-Kampff machine ? Voight-Kampff machine | Off-world: The Blade Runner Wiki | FANDOM powered by Wikia
    shabaz over 7 years ago in reply to dougw +5 suggested
    Agree.. I don't know why the OP excludes image processing - due to incorrectly perceived difficulty, or for a non-technical reason. I can understand the desire to possibly exclude due to (say) security…
    0 dougw over 8 years ago in reply to saikeerthana
    You probably need a lot of force sensors in the floor or you need a camera with image processing software.
  • mgviju
    0 mgviju over 7 years ago
    I would like know how we can detect only single person by using his image and like to know how
  • Robert Peter Oakes
    0 Robert Peter Oakes over 7 years ago
    So Facial recognition is a way more complex solution than simple presence detection, but there are plenty  of info out there, for instance, google facial Recognition on the raspberry pi
    For instance https://www.raspberrypi.org/blog/facial-recognition-opencv-on-the-camera-board/
  • balaraskutty
    0 balaraskutty over 7 years ago in reply to e14 Contributor
    If thermal sensor sense the presence of animal in particular area
  • aihtesham
    0 aihtesham over 7 years ago
    That's Interesting topic actually I am looking for same, recently in IOT I found many applications based on IOT that uses different sensors, But there are no any sensor exist that  could sense presence of life. Here life means every object in nature who have life given by god.
    I think we  need to discover the parameter of life that changes with presence of  surrounding as a example if people present in room may change the amount of CO2 that can be use to draw a conclusion that some life is in room.
    0 shabaz over 7 years ago in reply to aihtesham
    I think there is a misunderstanding about what a sensor does. A sensor detects one or several properties, such as temperature or light or chemical presence.
    You use the sensor to get some measurement of those properties. You can use those measurements, in some known environment, to make a conclusion, often based in part on some extrapolation.
    Here's a thought experiment. Pretend you're a computer system with vast power. How would you detect a human?
    What questions would you ask your sensor (it could be a human colleague pretending to be a sensor) so that you could make a decision if a human was present?
    If you asked the sensor to measure if the level of CO2 was changing (which was your example) then that could be defeated with a fire.
    If you as a human cannot imagine the tools to determine a human is present, how do you expect sensors (let alone "a" sensor) to do it? You'd probably need to check DNA to confirm it anything human is present and not an animal...
    What if the thing facing you was a human-looking robot with plastic skin on the outside, and it was warm just like a human, and internally had a cylinder of CO2?
    That being said, most "normal" methods provide a low but usable level of accuracy by making conclusions based on heat or image recognition or sound activity (for instance). Still easy to defeat with a photo of a human facing the camera, or an audio player..
  • BigG
    0 BigG over 7 years ago
    I also came across this blog only the other day.
    https://e2e.ti.com/blogs_/b/behind_the_wheel/archive/2018/04/30/detecting-vehicle-occupancy-with-mmwave-sensors#
    0 DAB over 7 years ago
    You can use a thermal IR sensor calibrated to 98.6 degrees F and it will tell you when a human is in its field of view.
    You have to have the sensor at that precise temperature to discriminate between humans and animals. Just be aware that if someone is ill, they would not be detected.
    0 shabaz over 7 years ago in reply to DAB
    Google thinks a horse has a very similar body temperature as a human.
    Besides, how would you know where to aim the sensor without first having a method of identifying a known part of the body, and identifying if it is covered or not (which will result in a very different temperature, depending on the thickness of the clothing). Every color here represents a slightly different temperature:
    Put simply, there is no easy simple answer. It cannot be done, apart from in a constrained environment, to a certain level of (un)reliability, and a single sensed property like just temperature would be easy to fool too.
    0 DAB over 7 years ago in reply to shabaz
    Agreed. You can have it simple or you can have it accurate or you can have it cheap.
    You cannot have all three.
