Arduino Forum Help with WiFi web server analog input code
  • Replies 14 replies
  • Subscribers 418 subscribers
  • Views 1930 views
  • wifi
  • web
  • scale
  • cell
  • load
  • weight
  • server
  • analog
Hi all,
I have written some code to display readings from an analog input (load cell from a digital scale) in my browser through a web server. However, when I have nothing on my load cell, the browser displays a weight value of -500 rather than 0. I know that the code I'm using for the load cell works, so the problem arises from how I've combined the load cell code with the WiFi web server code. I have tried to correct the issue, but I haven't been able to figure it out at all. Any help or ideas would be much appreciated. Thank you!
My Code
http://pastebin.com/embed_js.php?i=FsyCGy9Y
Sources
WiFi Web Server code: Tutorial: Arduino wi-fi server to Google Drive storage | Daviom
Load Cell code: https://github.com/Airtripper/load-cell-test/blob/master/load_cell_test.ino
The WiFi Web Server code uses a temperature sensor as the analog input and includes code for that purpose. I replaced the temperature sensor code with the Load Cell code.
Arduino_to_Google_Spreadsheet_7_14.ino.zip
  • vish
    0 vish over 12 years ago in reply to e14 Contributor
    Hi Michele,
    I think I didn't understood your problem correctly? Could you please tell me what value you are expecting  for analogSampleAverage? I was thinking it must be zero under unloaded condition.
    also check whether your analog pin is grounded( either the sensor output is grounded or whether and analog track is grounded)?
    and one more thing..
    float loadGrams = (analogSamplesAverage-analogLow)*(loadHigh-loadLow)/ (analogHigh-analogLow) + loadLow;
    in this formula, all the RHS variables are of integer type. So there is a possible chance of type casting error. Check that also.
    0 e14 Contributor over 12 years ago in reply to vish
    Hi everyone,
    Just wanted to let you all know that I did get my code working as it should by making the web server code a subroutine of the load cell code. Everything works well now!
    Thanks again for all the help!
  • vish
    wow...great image
  • Robert Peter Oakes
    0 Robert Peter Oakes over 12 years ago in reply to e14 Contributor
    I guess you never fount this while looking,
    http://www.element14.com/community/groups/arduino/blog/2014/06/21/fast-track-to-arduino-programming--lesson-4-ethernet-input-and-response, there are many there that I posted which may have helped you, or still could
    sorry I did not notice your post earlier
    Peter
