Arduino Forum What stops your Arduino project?
  • Replies 49 replies
  • Subscribers 415 subscribers
  • Views 17792 views
  • project
cstanton
cstanton over 4 years ago
Say you want to create a solution to a problem you have, like automating the door on a chicken coop with the time of day...
What tends to stop you from developing it? Do you find that you encounter a problem part way through the project? Is it some knowledge you're lacking or is it the software?
Would you benefit from help with circuit design? Or is it something else?
We're looking at expanding our introduction videos and guidance on using Arduino products, and I'm interested in what you need help with, so reply and let us know, regardless of knowledge level.
  • ralphjy
    ralphjy over 4 years ago +7
    I run into problems when sensors or peripherals that I want to use don't have libraries available for the Arduino IDE and it is necessary to port a library or develop one from scratch. I also have problems…
  • fmilburn
    fmilburn over 4 years ago +7
    I find the Arduino libraries helpful for most of my simple projects. Unfortunately, there is much poor Arduino code on the internet and care must be taken to find a good source. So, a list of reputable…
    shabaz over 4 years ago +7
    I just fired up Arduino and it printed this: void setup() { // put your setup code here, to run once: } void loop() { // put your main code here, to run repeatedly: } Which is ok, there…
    Jan Cumps over 4 years ago in reply to phoenixcomm
    It has the same drawbacks as a debugger - printf influences execution time and makes parallel processes run serial in some cases -
    without the benefits of a debugger. We're in 2022.
  • beacon_dave
    beacon_dave over 4 years ago
    I need to acquire the chicken coop first, and then stick a door on it...  Slight smile
    As already has been mentioned, becoming more proficient with the structuring of code for moving onto the intermediate to advanced projects. To some extent this probably falls outside the scope of Arduino and into more general good programming design techniques, however still need to keep in mind the more limited resources on Arduino devices and so can't afford all the general 'bloat' that typically accompanies other programming techniques and also that the user interfaces tend not to be based around the generic desktop keyboard/mouse/monitor.
    The official Arduino courses like the CTC GO! appear to be limited to schools as the core bundle is around $1,500 and the add-on modules around another $950 on top of that as they are designed for classes of up to 24 students rather than being aimed at individuals working alone. It would be interesting to hear from someone that has managed to access the course to find out what it was like, or similar courses that claim to go beyond the basics.
    I think the entry-level Arduino content is pretty well catered for through readily available on-line resources and printed texts. After that it appears to rely heavily on institutions working Arduino into their own curriculums for more structured content.
    Areas I'm interested in becoming more proficient in with the Arduino platform would include techniques for working with user interaction via multiline alphanumeric LCD/OLED displays, modular matrix LED displays and creating HMI type control panels; working with raw serial data capture, and working with multiple microcontrollers within the one project. Some more material covering the MKR Vidor 4000 would be welcome.
    Jan Cumps over 4 years ago in reply to beacon_dave
    If you have OO skills and know C++ constructs, but you find it difficult to stay consistent and write clean code:
    The book Industrial Strength C++ by Mats Henricson and Erik Nyquist has helped me. I used it to turn myself from a hobbyist to a professional developer on my first C++ job.
    It focuses on writing reliable object oriented designs. No tutorial on the language or how to be a Wizz, but recipes to use it 'like a pro'.
    It's out of print, but the authors provide a free and authorised download on the link above.
    • Vote Up +5 Vote Down
  • fmilburn
    fmilburn over 4 years ago in reply to Jan Cumps
    Thanks, I’ve added it to my reading list
  • phoenixcomm
    phoenixcomm over 4 years ago in reply to Jan Cumps
    Jan, get over it, in most cases a printf is all you need.
    A debugger is used nomally used in assembly code
    If you really want a debugger with breakpoints use Eclipse.
    dubbie over 4 years ago
    I think I might be in the minority as what stops me completing/working on a project is any or all of the list below:
    1) Gardening,
    2) Sleeping,
    3) Sleeping in the garden,
    4) Wine,
    5) wine in the garden followed by sleeping,
    6) Sleeping in the greenhouse (when it's too cold to sleep in the garden)
    7) Lack of technical knowledge and ability,
    8) When it stops being fun.
    I think that pretty much covers all my issues.
    Dubbie
    • Vote Up +6 Vote Down
  • BigG
    BigG over 4 years ago in reply to dubbie
    Laughing Laughing Laughing Yep, that sums it up brilliantly.
    dougw over 4 years ago in reply to dubbie
    That free bus pass might add to the list.
    TV didn't make the list?
    Tea didn't make it either?
  • cstanton
    cstanton over 4 years ago in reply to dubbie
    Mmm, other obligations do factor in to preventing projects from being worked on. That is entirely valid.
  • robogary
    robogary over 4 years ago
    1)  myself . Getting stuff to work , usually communication interfaces, to work easily really shatters my confidence and dedication.
    2) cost VS practicality curve. My project gets too elaborate & expensive for the amount of pleasure it gives  me or others.
