Arduino Forum If statements and functions.
  • Replies 11 replies
  • Subscribers 411 subscribers
  • Views 2576 views
SteveE14
SteveE14 over 3 years ago
I am new to Arduino, can you help me please?
The sketch is supposed to only run "myfunction" if "EnableState" is high. However, it runs the function irrespective of the state of "EnableState"
Thanks for taking the time to read this.
bool EnableState;
 void setup() {
// rem whatever
EnableState = LOW;
EnableState = HIGH;
 Serial.begin(9600); // opens serial port, sets data rate to 9600 bps
void loop() {
 Serial.println("In Void loop");
 Serial.println(EnableState);
      if (EnableState==HIGH);{
      MyFunction();
void MyFunction(){
    Serial.println("MyFunction");
      delay(1000);
    shabaz over 3 years ago +4
    Hi, The easiest way to spot this kind of issue is to paste it into a decent C/C++ editor, e.g. Visual Code. Then, if you press the Format option (Alt-Shift-F) the problem instantly becomes visible:
  • mayermakes
    mayermakes over 3 years ago +3
    you are litterally setting it to high in line 6, that is the last state it has before the loop, therefore it executes, if you delete line 6 or put it before line 5, the opposite will happen.
  • mayermakes
    mayermakes over 3 years ago in reply to shabaz +2
    i did not catch the stray ; , but still it wil lalso execute because of the declaration in setup.
  • phoenixcomm
    phoenixcomm over 3 years ago
    sir your Variable EnableState was set in line 6, and you could have done this
    void loop() {
    if (Serial.available() == Enable State) {
    MyFunction();}
    AND BTW Please download Eclipse IDE with the GNU tools for your Arduino.  It's open source and better than the rest.
    I use two different editors, Bluefish and SciTE, both are universal editors. For most of my HTML, I use Bluefish. Btw the hyperlinks will open new pages.
    imageOn the left is Bluefish
    and on the right is Eclipse with your program
    and when I rewrote it.
