Arduino Forum Problem uploading to ADAFRUIT Feather 32u4 using Arduino 2.1
  • Replies 14 replies
  • Subscribers 413 subscribers
  • Views 3687 views
  • board
  • problem
  • adafruit feather
  • uploading
  • upload
  • feather
  • adafruit
  • connecting
Alexander28
Alexander28 over 3 years ago
Hi all,
Long time fan of the technology, first time user of the forum.
Currently using a Windows 10 box, with Arduino 2.1 and the following board, from RS Components:
ADAFRUIT Feather 32u4 Development Board 2829
Long story short, I used to be able to upload to the board, and now it just hangs at the upload screen, then after 4-5 mins, gives me the below error.
I have used different USB Cables, USB ports and even computers, same issue. I am wondering if i am doing something silly...
This is what i am getting:
"Sketch uses 10934 bytes (38%) of program storage space. Maximum is 28672 bytes.
Global variables use 885 bytes of dynamic memory.
Connecting to programmer: .avrdude: butterfly_recv(): programmer is not responding
avrdude: butterfly_recv(): programmer is not responding"
Had a read of this too:
https://stackoverflow.com/questions/49283074/arduino-leonardo-avrdude-butterfly-recv-programmer-is-not-responding
have tried the 'reset button' before programming, getting the red pulsing light indicating it is resetting, and then tried the upload, still nothing...
Anyone know where i am going wrong?
Really appreciate any help, thank you all!
    dougw over 3 years ago in reply to Alexander28 +1
    The first reset just resets the MCU, the second reset puts the MCU into booloader mode via the USB port. It only stays in bootloader mode for a few seconds, so the double reset sequence needs to be performed…
  • ralphjy
    ralphjy over 3 years ago +1
    Did you follow the instructions in the stackoverflow link precisely? It says to press and hold reset and then start the upload - wait until compiling is complete and you see the “Uploading” message in…
  • Alexander28
    Alexander28 over 3 years ago +1
    Thank you to everyone who gave suggestions, most were right! I had to press the reset button twice during compile time and then it would load. New to me, thanks, got me right out of a pickle! Thanks everyone…
  • Alexander28
    Alexander28 over 3 years ago in reply to shabaz
    I am presently testing with 4 boards and two computers. Nothing attached to the board, as i thought same as you, that might foul it.
    I might also have a look at firewall issues?
    But sounds from your guys responses that the key here is in the reset / bootloader.
    Thanks again, i will report back...
  • Alexander28
    Thanks everyone once again!!
  • Alexander28
    Alexander28 over 3 years ago in reply to Alexander28
    Yup, see final reply, worked like a charm.
  • Alexander28
