Arduino Forum Looking for a way to calibrate an anemometer in order to measure the wind speed
  • Replies 13 replies
  • Subscribers 404 subscribers
  • Views 3570 views
  • wind
  • anemometer
  • weatherstation
  • drag
  • physics
gekkoscamp
gekkoscamp over 5 years ago
Hello guys,
(My first post on this forum, so ill introduce myself post scriptum)
To get into smart home systems and arduino, I am currently building a weather station measuring temperature, humidity and all kinds of funny stuff.
I am ALSO measuring the rotations of a self built 3d printed anemometer. I know the dimensions of the "flaps/cups", i know the rotations/frequency with which the thing is spinning
but i simply cant think of how to calculate the windspeed, given rotations and the drag value of a half sphere (in German its called Cw-Wert).
The actual spinning part consists of 3 equally spaced "arms" of length d each with a half sphere with diameter a.
How do I calculate the Windspeed, given those parameters?
Any hints are super appreciated.
Hi, this seems like a really cool and friendly forum so i decided to sign up.
My Name is Michael, studying engineering in Germany, eager to learn the basics of electronics and programming.
    DAB over 5 years ago +6
    Hi Michael, Welcome to element14. What accuracy are you hoping to attain with your anemometer? A simple test is to put it on your car and drive at various speeds on a calm day. You can run through a series…
    michaelkellett over 5 years ago in reply to DAB +5
    I've seen it done from a car but better on the back of a motor bike if you have a friend to give you a ride. It's easier to hold the sensor out of the slipstream on a bike. If it were me I'd put it on…
    jw0752 over 5 years ago +4
    Theoretically you are looking at the rate that a small volume of air moves from the tip of your blade to the back of the blade. Each movement of the air (tip to back) creates a partial rotation of the…
    Theoretically you are looking at the rate that a small volume of air moves from the tip of your blade to the back of the blade. Each movement of the air (tip to back) creates a partial rotation of the fan. Calculation of how many tip to backs are required to produce one rotation would tell us the ratio for one rotation compared to the rate of air movement tip to back of blade. Suppose that there is one cm of depth to the fan blade and the air is moving that distance in 1/100 second. (1 Meter per second). Suppose it takes 5 of these tip to back cycles to get one rotation. From this we would know that ideally with no friction 1 Revolution would equal 5 times the the tip to back speed of the air. (5 X 0.01 sec = 1/20th second) In this example our hypothetical air speed of 1 meter per second should produce 20 rps or 1200 rpm. I did these calculations on the fly in in my head so please check them and critique is welcome. Unfortunately friction is part of the real world and in this case it isn't even linear. As the fan speed increases the friction will increase in a non-linear fashion due to the air around the fan that has to be moved by the back of the blades. In the end if you want reasonable accuracy the methods proposed by Michael and Donald are probably the best. If you can find or borrow an Anemometer then you can use a stationary fan or a hair dryer to simulate a wind and make your calibrations without trying to drive down the road with a 2 meter pole out the window. Make your calibration at a wind speed that is in the middle of the range you expect to measure for best accuracy over the entire range.
  • phoenixcomm
    phoenixcomm over 5 years ago in reply to jw0752
    imageMy G-d what is with all of you trining to redesign the world. I have a Fieldpiece AAV3 head for my EHDL1   >
    Reads
    Ft/mi or M/s
    MPH or KM/hr
    ~~Cris
    jw0752 over 5 years ago in reply to phoenixcomm
    I can't speak for anyone else but for me it is fun to try to do it the hard way sometimes.
  • BigG
    BigG over 5 years ago in reply to jw0752
    and this tends to be the best way to learn. image
    Gosh, even Elon Musk (Tesla) points this out when he was reported as saying "(to) Make better products, seek negative feedback and ditch those PowerPoints presentations (or as I interpret, ditch those product brochures)."
    https://www.cnbc.com/2020/12/08/elon-musks-advice-to-ceos.html
