Arduino Forum RGB LED night light
  • Replies 15 replies
  • Subscribers 408 subscribers
  • Views 1230 views
  • light
  • arduino_uno
  • night
  • leds
  • reg
RGB LED night light
josh_j
josh_j over 12 years ago
Ok this is what I'm trying to do. I want to create a RGB LED night for my girlfriend using an Arduino and have the LEDs fade through different colors. I want to drive at least 6 LEDs. I've been talking to people on the Arduino Google+ group but this one guy gave me a schematic for my idea, but I'm really really new to all this. Is there a driver board for RGB LEDs that I can buy and use that and the Arduino to make this? I just want something that will do what I'm planning but is easy for newbies like myself. It would be cool too if the Arduino could detect the ambient light in the room and come on as needed. I would also buy a 9V wall adaper for so the Arduino could run off power from a outlit.
If someone on here is able to help me work through this project and give me ideas and easy ways of creating this for my GF that would be amazing!
P.S. I have a Arduino Uno
Thanks!
Josh
    mcb1 over 12 years ago in reply to josh_j +1
    By chance did you look at the Adafruit tutorial.? I'm sure the fact you did the code (rather than have someone else supply) will impress you girlfriend. mark
  • ntewinkel
    ntewinkel over 12 years ago in reply to josh_j +1
    Cool project! You'd have to add the variable resistor to one of the analog inputs, and then use analogWrite to output to the LED. Oomlout has a basic example (See "Making it better, Control the Brightness…
  • ntewinkel
    Cool project!
    Oomlout has a basic example (See "Making it better, Control the Brightness") http://www.oomlout.com/oom.php/products/ardx/circ-01
    For a diffuser, I've seen people use pingpong balls, drinking straws, and also plexiglass covered with "invisible tape".
    Cheers,
    -Nico
  • josh_j
    josh_j over 12 years ago in reply to ntewinkel
    thanks I'll look into it! I'm really gonna have to take some time learning all the coding for this whole thing. lol
  • josh_j
    Also I just noticed that the analogpins the variable resister is going to use are also the same pins that the adafruit NeoPixel Shield uses. How do I wire it it so they work together?
  • josh_j
    josh_j over 12 years ago in reply to mcb1
    Which tutorial was that? Could you be send the the link to it?
    its the tab on the right of the page link you sent.
