Arduino Forum need help urgently..
  • Replies 15 replies
  • Subscribers 403 subscribers
  • Views 1394 views
i m making software with arduino..there is some sensor types and they have particular ids like
temp1       sensor id=1         decimal value 49(accordingto ascii code)
like this there are 8 different sensors.i hvae to '
read the serial
store in a data array
compare 1st byte against sensor id
copy rest of data from and display to serial pc
please can anybody help me in coding
please
    Former Member over 11 years ago in reply to Robert Peter Oakes +1
    THANKS Peter thanks so much.. you are really very helpful person
    mcb1 over 11 years ago
    Harman
    It helps if you post the code ... otherwise its like "Can you see that".
    use the >> and Syntax Highlighting C++ and copy the code in
    Fullscreen contentimage_182515.html Download
    <html><head><title>Jive SBS</title></head>
    <body><font face="arial,helvetica,sans-serif">
    <b>Error</b><br><font size="-1">
    An general error occurred while processing your request.
    </font></font></body></html>
    mark
    Harman
    mark
    Former Member over 11 years ago in reply to mcb1
    thnks Mark for replying
    void setup ()
    //initialise serial communication with computer
      Serial.begin(9600);
    // initialize all reading to 0:
    char indata[20];
    int Serial_counter
    void loop()
      //write loop that will control what we want the arduino to do with sensor readout
      Serial.write("1:23:7");
      if(Serial.available()>0) //dont read unless there you know there is data
    indata = Serial.read(); //read a integer
    Serial_count++;
    if(indata[0]=='49')
      Serial.print("temp1=");
      Serial.print1n(1:23:7);
    dont know this is right or wrong but i tried for one sensor
    mcb1 over 11 years ago in reply to Former Member
    Harman
    Where did you get this from.?
    You have one unclosed brackets. (Proper indentation helps spot it) and you used a 1 instead of lowercase L in the Serial.println(1:23:7) statement
    char indata[20];
    int Serial_counter
    void setup ()
      Serial.begin(9600);
    void loop()
        Serial_count++;
        if(indata[0]=='49')
          Serial.println(1:23:7);        // this should have been println as 'ln' not 'one' n
    I presume it came up with errors.
    I haven't tried it.
    mark
    thanks but still it shows error.i just take help from internet and try to display ..but it didnt workimage..i was doing another project but due to some circumstances they change it and i dont know much about arduino ...please help me
    Harman
    Don't cross post as it makes it hard to follow which answer works.
    Post the error you get when you compile it and maybe then someone can assist.
    Also the internet is really big ... so the link to where you copied it form might help.
    mark
    these following error shown when i compile it..i didnt just copied all the data. i read and try to write code
    finallll:5: error: expected initializer before 'void'
    finallll.ino: In function 'void loop()':
    finallll:17: error: incompatible types in assignment of 'int' to 'char [20]'
    finallll:18: error: 'Serial_count' was not declared in this scope
    finallll:23: error: expected `)' before ':' token
  • Robert Peter Oakes
    Robert Peter Oakes over 11 years ago in reply to Former Member
    Hi Harman, Im feeling like being extra helpful today so...
    I had a bit of time at lunch so here is a quick framework to get you started, lots of room for improvement but good enough for a beginner to follow
    As Mark said, not sure where your code came from but lots of errors in it
    the following is based on your code but added structure and capability
    demonstrates modular program and reasonably good structure, as I said, not much time
    // declare global variables at top so there easy to find and modify
    char indata[20] = "" ; // assign empty string so we dont get issues with unterminated strings
    int Serial_counter = 0; // you had ; missing
    const int sensorCount = 3;// do as many as needed for sensors
    int sensorVal[sensorCount]; // assumes sensor input is an integer and or converted to an integer before storing
    void setup ()
        Serial.begin(9600);
         //do other initialization like the sensors if needed
         sensorVal[0] = 10;
         sensorVal[1] = 20;
         sensorVal[2] = 30;
    void loop()
        readSensors();
        processCommand();
    void readSensors()
      //this would normally be reading from real world sensors
     for (int count = 0 ; count<sensorCount ; count++)
          // normally you would read the sensor and input to the array
          sensorVal[count]++; // increment the dummy sensor value each time it is accessed
    void processCommand()
      while(Serial.available() > 0) // Don't read unless
      // now you know there is data
         if(Serial_counter < 19) // One less than the size of the array, dont want memory leak
           indata[Serial_counter] = Serial.read(); // Read a character
           Serial_counter++; // Increment where to write next
           indata[Serial_counter] = '\0'; // Null terminate the string
      // now compare the read string with a number of preset values
      // and if in range print value
      if (indata ==  "sensor1")
          printSensor(0); // 0 indexed array
      else if (indata == "sensor2")
          printSensor(1); // 0 indexed array
      else if (indata == "sensor3")
          printSensor(2); // 0 indexed array
      else if (indata == "All")
             printSensor(count); // 0 indexed array
       else
          Serial.println("Invalid Sensor ID");
          Serial.println(indata); // send back what we received
          Serial.println("was not found");
    // so we don't have to duplicate the print code for every sensor and waste flash memory
    void printSensor(int sensorID)
        Serial.print(millis());  // asuming this will be replaced with some time value
        Serial.print("Sensor ") ;
        Serial.print(sensorID);
        Serial.print(" =");
        Serial.println(sensorVal[sensorID]); // this would be replaced with the actual read value
    Harman, hope you can now adapt for your use, adding sensor reading and time output etc etc.
    Mark, feel free to add what you feel will help or if I made a mistake
    Peter
    mcb1 over 11 years ago in reply to Robert Peter Oakes
    Peter
    It was 2am, and I wasn't feeling like writing someone else's code for them.
    I was going to find a tutorial since it seems the basics aren't understood, so obviously more learning is required.
    To me it seems that this was part of a bigger project that involved serially connected sensors, or it was an assignment.
    Robert Peter Oakes over 11 years ago in reply to mcb1
    Agreed, that's why I only provided a basic framework, there is still plenty to do to get a viable program running and I needed something like this for myself anyway
    Peter
    THANKS Peter thanks so much..image
    Thanks Mark for your guidance..due to some circumstances i have to do coding but i not good in coding and time is very less for deep study.so  thats why i m request for help...
