Arduino Forum Arduino Loop Help Needed
  • Subscribers 413 subscribers
  • Views 771 views
  • arduino uno rev3
  • program
  • im an idiot
slackerisme
slackerisme over 6 years ago
I'm trying to code a program made up of borrowed code form different folks, I have the parts working separately, so I know its me that is the issue. What happens, code runs, I get one serial port reading displayed and th rest of the code functions. What I desire, the code to check if the light is on to prevent freaking out my neighbors with flashing lights in the shop.
I assume I need to nest the loop somehow, beyond that my experience is nil.
Thank you.
// name your pins:
int photocellPin = A0; // Photoresistor at Arduino analog pin A0
int red = 12;        //stop
int yellow = 11;     // floor it
int green = 10;      //Go!!!
int val = 0;
// the setup routine runs once when you press reset:
void setup() {
  Serial.begin(9600);
  // initialize the digital pin as an output.
  pinMode(red, OUTPUT);
  pinMode(yellow, OUTPUT);
  pinMode(green, OUTPUT);
  pinMode(photocellPin, INPUT);// Set pResistor - A0 pin as an input
int  var = 0; //defines and sets initial value for variables used below
int var1 = 0; //defines and sets initial value for variables used below
// the loop routine runs over and over again forever:
void loop() {
val = analogRead(photocellPin);   // read the value from the sensor
  Serial.println(val);   //The serial will print the light value
// sets initial value for pins so that lights start as "off"
digitalWrite(green, HIGH);
digitalWrite(yellow, HIGH);
digitalWrite(red, HIGH);
if (val > 200){
while(var < 25){
  // repeats normal cycle 25 times
  digitalWrite(green, LOW);   // turns the green light on
  delay(20000);               // holds the green light on for 20 seconds
  digitalWrite(green, HIGH);    // turns the green light off
  delay(600);               // slight pause between lights
  digitalWrite(yellow, LOW);  //turns the yellow light on
  delay(4000); //holds the yellow light for 4 seconds (watch out for that red-light camera!)
  digitalWrite(yellow, HIGH); //turns the yellow light off
  delay(600);  //slight pause between lights
  digitalWrite(red, LOW);  //turns the red light on
  delay(20000);  //holds the red light on for 20 seconds
  digitalWrite(red, HIGH);  //turns the red light off
  var++;}  //adds 1 to variable "var" for repeat count
  // after 25 cycles above, the light switches to "power outage mode", flashing red
  delay(600); //slight delay
  var1=0; //resets variable "var1" to 0
  while(var1 < 120) {
    // repeats power outage cycle 120 times - 2 minutes
   delay(600);
   delay(400);
   var1++;}
var = 0;
//switches back to normal cycle after "power outage" cycle is done
while(var < 25){
  // back to normal light cycle for 25 cycles
  digitalWrite(green, LOW);   // turn the LED on (HIGH is the voltage level)
  delay(20000);               // wait for a second
  digitalWrite(green, HIGH);    // turn the LED off by making the voltage LOW
  delay(600);               // wait for a second
  delay(4000);
  delay(600);
  delay(20000);
  delay(600);
  var++;}
  delay(600);
//switches to "late night cycle" flashing yellow for 2 minutes, similar to flashing red above
var1=0;
  while(var1 < 120) {
   delay(600);
   delay(400);
   var1++;}
   var = 0;
else{
  • Gough Lui
    Gough Lui over 6 years ago +2 suggested
    Next time, it may help to place the code in a special code block by using the Insert -> Syntax Highlighting -> c++ feature. Your code seems to have a lot of strange stylistic issues including inconsistent…
  • Gough Lui
    0 Gough Lui over 6 years ago
    Next time, it may help to place the code in a special code block by using the Insert -> Syntax Highlighting -> c++ feature. Your code seems to have a lot of strange stylistic issues including inconsistent indenting, spaces, etc. Regardless, from my understanding, you've got a traffic-light style light which is active-low that you are controlling to display a four different sequences (normal, power outage, normal, late night) repeatedly, but only if the lights are "on" in the shop (i.e. LDR senses light above a threshold).
    The problem is that, in the way you have structured your code, the Arduino is only going to read the photocell once every time it finishes the full sequence due to the way you have wrapped the whole block inside an "if" statement. This is probably not what you intended - instead you probably wanted the photocell to be checked fairly often so that once the shop lights go out, the traffic lights go out soon thereafter.
    There are many different approaches you can take - one of them is to embed the check for the photodiode value "all over the place" (e.g. at every place where the lights might be turned on) - probably best to wrap it into a function to save repetition. This has the advantage of relatively fast response, but also results in spaghetti code and perhaps more delays than is necessary.
    Instead, I suggest that you remove the initial read for the photodiode at the beginning and instead move the photodiode check into your while loops, so that they "break out" in case of light exceeding the given value -
    e.g. while (var<25 && analogRead(photocellPin)>200) where the && operation means a "logical and". The problem will be that you will need also to cater for the situation where the photocellPin value goes high mid-loop and a light is stuck on - hence leaving the off code in the loop should help. In good programming style, I've redefined the threshold number using a #define so that it can be changed in the header just once, and changed the indenting to be a little more comprehensible (at least, to me). As I don't have your equipment, I have no idea how this code will behave but perhaps you can give it a try:
    #define PHOTOCELL_THRESHOLD 200
    // name your pins:
    void setup() {
      Serial.begin(9600);
    void loop() {
      var = 0;
      while(var < 25 && analogRead(photocellPin) > PHOTOCELL_THRESHOLD){
        var++;
      while(var1 < 120 && analogRead(photocellPin) > PHOTOCELL_THRESHOLD) {
        delay(600);
        delay(400);
        var1++;
      var = 0;
        delay(4000);
        delay(600);
        delay(20000);
        delay(600);
        var++;
      delay(600);
      var1=0;
        delay(600);
        delay(400);
        var1++;
    Also note that in your code, you don't actually need both var and var1 - they could have both been var as you don't use both concurrently. The one potential downside is that this version does not print the photocell value over serial anymore. If you want to do this, you could instead add the code to read at the end of the while loops instead - e.g.:
    # Must add int val = 0; declaration at the beginning
    # Prior to commencing the loop, val must contain present photodiode reading - i.e. val=analogRead(photocellPin); at a minimum
      while(var < 25 && val > PHOTOCELL_THRESHOLD){
        var++;
    There is potential for a lot of improvement in the code, but at least I hope this code is closer to what you were hoping to have.
    - Gough
