Arduino Forum Need with Servo control using Kinect (Hand Tracking) + Processing + Arduino
  • Replies 18 replies
  • Subscribers 413 subscribers
  • Views 2399 views
Hi Everyone,
                     A part of my final internship is to use the Kinect to track a hand and use the cordinates to control the servo motor. .
I had written a program which recognizes the user's hand , converts the position to X-Axis cordinates (relative to the 640 x 480 window).
However the program seems to have a bug and i am not able to recognise where the bug is.
The program recognises my Hand as expected ( pointed out by a bright red spot drawn using ellipse command) and a println command reproduces the x_cordinate values and everything is in oder).
When i move my hand from left to right, the servo first makes a -180° turn (somewhere between 40 and 55 from the println values). Then the servo motor follows my hand but stops at a certain point (around 240 from the println values).
I have included both my arduino program and the Processing program.
I have been stuck here for the past three weeks, it would be great if someone can help me out please
Arduino Program
#include <Servo.h>
Servo servo1; Servo servo2;
void setup() {
  pinMode(1,OUTPUT);
  servo1.attach(14); //analog pin 0
  //servo1.setMaximumPulse(2000);
  //servo1.setMinimumPulse(700);
  servo2.attach(15); //analog pin 1
  Serial.begin(19200);
  Serial.println("Ready");
void loop() {
  static int v = 0;
  if ( Serial.available()) {
    char ch = Serial.read();
    switch(ch) {
      case '0'...'9':
        v = v*10 + (int)(ch - '0');
        break;
      case 's':
        servo1.write(v);
        v = 0;
        break;
      case 'w':
        servo2.write(v);
        v = 0;
        break;
      case 'd':
        servo2.detach();
        break;
      case 'a':
        servo2.attach(15);
        break;
Processing Program
import SimpleOpenNI.*;
import processing.serial.*;
SimpleOpenNI kinect;
Serial port;
float spos=90;
float currentX;
float lastX;
float currentY;
float lastY;
int x;
int y;
float interpolatedX;
float interpolatedY;
ArrayList<PVector> handPositions;
PVector currentHand;
PVector previousHand;
void setup(){
  size (640,480);
  println(Serial.list());
  port = new Serial(this, Serial.list()[0], 19200);
  kinect= new SimpleOpenNI(this);
  kinect.setMirror(true);
  kinect.enableDepth();
  kinect.enableGesture();
  kinect.enableHands();
  kinect.addGesture("RaiseHand");
  handPositions = new ArrayList();
void draw(){
  kinect.update();
  image(kinect.depthImage(),0,0);
  for (int i=1;i<handPositions.size();i++){
    currentHand=handPositions.get(i);
    previousHand=handPositions.get(i-1);
    currentX=(currentHand.x);
    lastX=(previousHand.x);
    currentY=(currentHand.y);
    lastY=(previousHand.y);
    float interpolatedX = lerp(lastX,currentX,0.3f);
    lastX = int(interpolatedX);
    float interpolatedY = lerp(lastY,currentY,0.3f);
    lastY = int(interpolatedY);
    x= int(lastX);
    y= int(lastY);
    fill(255,0,0);
    ellipse(lastX,lastY,15,15);
    spos= lastX/4;
    x= int(lastX);
    println (x);
    port.write("s"+spos);
    void onCreateHands(int handId, PVector position, float time){
      kinect.convertRealWorldToProjective(position,position);
      handPositions.add(position);
    void onUpdateHands(int handId, PVector position, float time){
    void onDestroyHands(int handId, float time) {
      handPositions.clear();
    void onRecognizeGesture(String strGesture, PVector idPosition, PVector endPosition) {
      kinect.startTrackingHands(endPosition);
      kinect.removeGesture("RaiseHand");
  • billabott
    0 billabott over 13 years ago
    It is a shame you did not include more comments in your code.
    I think it would be most helpful to you and to 'US' if you can go thru the code and add as many comments as you can.
    The only thing that jumps out at me is in the following code segment:
        fill(255,0,0);
        spos= lastX;
        x= int(lastX);
        println (x);
        port.write("s"+spos);    // reviewer not sure if float value is what is needed/intended to be sent via write
    Should the float value spos be cast as type int() before prefixing an "s" to the string being written out to the serial port?
    Best of Luck to You.
  • bad_boy_y
    0 bad_boy_y over 13 years ago in reply to billabott
    the motor is continuous turning?
    0 Former Member over 13 years ago in reply to bad_boy_y
    Yes...The motor rotates contionously and stops when my hand reaches 0 or 640 ...
    0 Former Member over 13 years ago in reply to billabott
    Am Sorry, i am new to both processing and programming. I have included the comments now
    Serial port;
    float spos=90;
    float currentX;
    float lastX;
    float currentY;
    float lastY;
    int x;
    int y;
    void setup(){
      size (640,480);
      kinect.setMirror(true);                                                  // Mirrors the image
      kinect.enableDepth();                                                  // Enable Depth Map Generation
      kinect.enableGesture();                                               // Enables Gesture generation
      kinect.enableHands();                                                 // Enables Hand identification
      kinect.addGesture("RaiseHand");                                // Recignises the Raised Hand Gesture
      handPositions = new ArrayList();                                 // Stores the values from PVector (hand positions over time)
    void draw(){
      kinect.update();
        x= int(lastX);
        y= int(lastY);
        fill(255,0,0);
    // This part of the code has been adapted from the tutorial on the arduino website  http://www.arduino.cc/playground/Learning/SingleServoExample
    spos= lastX/4;                                                  // Calculate the servo position from lastX
        x= int(lastX);
        println (x);
        port.write("s"+spos);                                         // Output the Servo Positions from 0 to 180
  • billabott
    0 billabott over 13 years ago in reply to Former Member
    //Output the servo position ( from 0 to 180)
    as found on : http://rouvelle.com/rai_sp_12/
    Can you be a little be more accurate on how your servo is moving and possibly
    investigate the range of values allowed for spos?
    I adapted that piece of the code from herehttp://www.arduino.cc/playground/Learning/SingleServoExample
    Well ummmmm, you see we have this 640x480 window
    When my hand moves towards the left, the motor also rotates and stops when i reach "0" and when i move my hand towards the right then the motor turns in the opposite direction and stops when my hand reaches "640".
    Basically the program is the same as in http://www.arduino.cc/playground/Learning/SingleServoExample here the X-cordinates from the mouse is used to control the motor while i use the X coordinate from the Hand tracking to control the motor
  • billabott
    You said: "The motor rotates continuously and stops when my hand reaches 0 or 640 ..."
    Your use of the word continuously in that manner suggests that the servo is rotating 360 non-stop!
    But, if I were to assume that you truely have a standard servo, then I know that its behavior is +/- 90 degrees from its center position based on if the PWM of the control signal being more or less than 50% duty cycle.  Does that make sense to you?
    If so, POINT ONE is that your real requirement is to scale the 0 to 639 xpos onto the Pulse width of the output pin controlling the servo.  Let us say that an xpos of 639 corresponds to 10% duty cycle and an xpos of 0 is 90% duty cycle.  [Could be the other way around, depending on your motor and/or circuit.]  You should work toward making your code do that (if I have understood your project correctly).
    POINT TWO, it seems to me that when you turn on the equipment one of the first things the arduino software should do is INITIALIZE the PWM to 50% and thereby CENTERING the servo motor arm position.  That corresponds to xpos of what?  Answer = 319.  There is no need for the servo to be moving unless the hand is detected within the field of view.  Therefore, it is unnecessary to pass any values to the arduino until there is a confirmed hand in the field of view.  You may even want to do a sort of debouncing of the detected hand position value to make sure that it is really present for more that a millisecond.
    Optional Question to ponder: If the hand being tracked leaves the field of view,  what position should the servo assume?
    Thanks for taking the effort to go through my whole program ... As i mentioned earlier, i am a total beginner to programming..
    Point One : The program behaves exactly as the example program. The motor follows the mouse in the example program and in mine the motor follows the hand.
    Point Two : The Servo doesnt move until the hand appears within the view of the camera and once the hand is recognised it follows the hand irrespective of the position it is now. And once the hand goes beyond field of view, the motor stops (The whole Point TWo part actually works)
  • billabott
    Well, that sounds wonderful.  Could you please clarify again what it is that does not work the way you wish?
    When i move my hand from left to right, the servo first makes a -180° turn (somewhere between 40 and 55 from the println values). Then the servo motor follows my hand but stops at a certain point (around 240 from the println values).  I want it to move continously like in this video
    http://www.youtube.com/watch?v=S1SEuHJAZYg
    The program in the video is similiar to our program except that i used nearest pixel detection for the program in the video and here i am using gesture detection
