Arduino Forum Android control Arduino over usb
  • Subscribers 400 subscribers
  • Views 1974 views
  • android_development
  • arduino relay
nicolaoscon96
nicolaoscon96 over 4 years ago
Hello there..
I need help...i m trying to make an app on android studio that i can connect an arduino with usb and control relays with toggle buttons. I tried everything i found on the internet but nothing worked. Anyone that worked on a similar project to help? I don't want to write on a command line and send it i want to have togglebuttons and went pressed turn on relay or off
I put USB between Arduino and the phone because it will stay on one place. No need for wifi or bluetooth
Other apps on GooglePlayStore work with the arduino but I don't want them like those.
I wrote the app just can't made the connection.
  • BigG
    BigG over 4 years ago
    I assume from your comment "Other apps on GooglePlayStore work with the arduino but I don't want them like those" that you've confirmed that your phone/tablet has OTG capability (https://www.carlcare.com/global/tips-detail/how-to-fix-usb-otg-android-not-working/ )
    I'd suggest searching online about Android OTG/USB Host mode and connecting your phone/tablet to Arduino. Here's two results I pulled off Google.
    https://developer.android.com/guide/topics/connectivity/usb
    https://www.allaboutcircuits.com/projects/communicate-with-your-arduino-through-android/
  • BigG
  • nicolaoscon96
    nicolaoscon96 over 4 years ago in reply to BigG
    My device support OTG, I have already connected the arduino to my phone using ArduinoDroid IDE and i can send and receive data from the arduino.
    I m just trying to make the serial communication between my app and the arduino
  • BigG
    BigG over 4 years ago in reply to nicolaoscon96
    Have you tried or are you using Flutter with Android Studio to develop your app? If so, you could use this widget to handle serial communication: https://pub.dev/packages/usb_serial
