Arduino Forum Unable to upload code to Adafruit Feather nRF52832
  • Subscribers 399 subscribers
  • Views 1953 views
  • help
  • port
  • nrf52832
  • feather
Frozen_Emerald
Frozen_Emerald over 2 years ago
I followed the guide https://learn.adafruit.com/bluefruit-nrf52-feather-learning-guide/arduino-board-setup and it keeps giving me this error.
Failed to upgrade target. Error is: Attempting to use a port that is not open
Traceback (most recent call last):
File "__main__.py", line 296, in serial
File "dfu\dfu.py", line 235, in dfu_send_images
File "dfu\dfu.py", line 206, in _dfu_send_image
File "dfu\dfu_transport_serial.py", line 213, in send_firmware
File "dfu\dfu_transport_serial.py", line 241, in send_packet
File "serial\serialwin32.py", line 306, in write
serial.serialutil.PortNotOpenError: Attempting to use a port that is not open
Possible causes:
- Selected Bootloader version does not match the one on Bluefruit device.
Please upgrade the Bootloader or select correct version in Tools->Bootloader.
- Baud rate must be 115200, Flow control must be off.
- Target is not in DFU mode. Ground DFU pin and RESET and release both to enter DFU mode.
When I tried to burn the bootloader it gives me another error. Every forum post of this error usually seems to have more options in the tools menu maybe its something to do with that.
Failed to burn bootloader: cannot execute upload tool: exec: "C:\\Users\\<name>": file does not exist
  • mayermakes
    mayermakes over 2 years ago in reply to baldengineer +4
    the classic power only blunder...I will never forgive any manufacturer of those cables.
  • baldengineer
    baldengineer over 2 years ago +3
    First, verify in device manager that a COM port appears and disappears when you connect/disconnect the board. If not, it could be missing serial drivers. According to the schematic , they're using a…
  • mayermakes
    mayermakes over 2 years ago +1
    this looks like a permission error, don´tt know how ito solve on windows, but under linux its a missing udev rule / the user has to be a member of the dialout group. under windows a serial driver could…
  • mayermakes
    under windows a serial driver could simply be missing.
  • Frozen_Emerald
    Frozen_Emerald over 2 years ago in reply to mayermakes
    I just checked and the user has Admin perms, how do I check which windows serial drivers i have and which one I need
  • mayermakes
    mayermakes over 2 years ago in reply to Frozen_Emerald
    check the documentation of the board you are trying to program, depending on which USb to serail chip it uses a different driver may be needed.
  • baldengineer
    According to the schematic, they're using a CP2104 in that board. Google says you can get the CP2104 drivers here.
    If device manager does not update when you connect/disconnect the board, there is a good chance your USB cable is power-only.
  • mayermakes
