    • Avnet Boards Community
ZedBoard Hardware Design Accessing LEDs and Switches in Xillinux
  • Replies 21 replies
  • Subscribers 333 subscribers
  • Views 2625 views
Hi there,
I've installed Xillinux on my ZedBoard, and I'm wanting to simply read switch values and write LED values, like in the ZedBoard Getting Started Guide, but I don't see anything in /sys/class/gpio, only export, unexport and gpiochip0. I've read and tried a lot of things to get it working, but don't seem to be getting anywhere.
Can anybody please explain to me how to go about achieving this?
  • jafoste4
    jafoste4 over 8 years ago +1
    Hi, You could try taking a look at these documents, especially lab 3 http://zynqhowto.blogspot.kr/search?updated-max=2014-04-02T19:44:00-07:00&max-results=7 --Josh
  • 100dsp
    0 100dsp over 8 years ago
    If I don't want to include VIVADO and wants to program on Zedboard using Xilinx SDK by writing code in C.............is it possible...??
    Tell me what type of problem may be....??
  • jafoste4
    0 jafoste4 over 8 years ago
    Hello DSP,
    You need to generate a bitstream in Vivado.
    --Josh
  • 100dsp
    Any block design tutorial which may consist set of examples of different applications for VIVADO...?
  • niknik
    0 niknik over 8 years ago in reply to 100dsp
    Try this:
    http://www.zynqbook.com/download-tuts.html
  • 100dsp
    0 100dsp over 8 years ago in reply to niknik
    I have to use Zedboard for signal processing application.
    Please, help in the requirements and the relevant tutorial for my application.
    1- I want to take analog input from sensors
    2- I want to control the samples of input signal
    3- I want to apply my algorithms over that samples.
  • 100dsp
  • jafoste4
    --Josh
  • 100dsp
    I want to take analog input using FMC LPC connector please provide some relevant project developed on zedboard using vivado and sdk.
  • jafoste4
    Hello DSP,
    Here are all the reference designs we offer for the Zedboard http://zedboard.org/support/design/1521/11
    If you need somthing else i am going to suggest you ask at the Xilinx forum to reach a broader audience.
    Thank you,
    Josh
  • 100dsp
    Please, anyone, help me in finding the way how to interface AD7768 adc with Zedboard using FMC.
    what are the basic steps required to interface two hardware using FMC-LPC card?
    I am using VIVADO and Xilinx SDK as a development platform.
    I am stuck at this point from longtime please help me out of this problem.
     Link given below is not found very much helpful
