NI LabVIEW Community
  • NI LabVIEW Community
NI Forum (solved) help request: capture VISA communication of a SRQ (service request) scenario (LabVIEW or PyVISA)
  • LabVIEW Challenge Blogs
Join NI LabVIEW Community to participate - click to join for free!
  • Replies 9 replies
  • Subscribers 130 subscribers
  • Views 2094 views
  • USBTMC
  • labview
  • srq
Jan Cumps
Jan Cumps over 2 years ago
I'm looking for support from someone that owns an instrument that supports SCPI Service Requests, to run a trace on the VISA traffic.
This is to support my attempt to add this functionality to  PST.. Experimental event / trigger support for Pico SCPI labTool - 1: investigate .
My project has this functionality:
  • it knows when it has to send the notification to the host system
  • it does not know how to send it over usbtmc, mostly:
  • I have a hard time understanding
    • what data I should send back (I think the STATUS BYTE),
    • in what format (I could not find it in the specifications),
    • and if it should send it over the USB common endpoint or trigger endpoint
My ask
If you have a SCPI instrument with these options:
  • SCPI / VISA
  • USBTMC (prefered, if not, then GPIB or VXII also have a comparable service request mechanism)
  • service requests functionality available
To run an example that uses service requests, and to capture traffic with NI I/O Trace (or the variant of the VISA version you use).
If you have LabVIEW, there is an example VI that uses this:
Help -> Find examples -> Search
Keyword: service -> Search
Open SQR Event Handling
Before running, select your instrument.
In the SCPI string, enter a SCPI command that would use the SRQ mechanism of your instrument.
If you don't know a command, I will try to work with you, using the program guide of your instrument.
this post says it should be 0x81 + the STB.
(ggabe , Gough Lui , baldengineer  maybe you have experience?)
    Jan Cumps over 2 years ago in reply to baldengineer +3 verified
    solved. PST.. Experimental event / trigger support for Pico SCPI labTool - 7: Test Service Request from Instrument to LabVIEW flow
    0 Jan Cumps over 2 years ago
    My own DMM6500 may be able to do this:
    0 Jan Cumps over 2 years ago in reply to Jan Cumps
    It failed. The flow timed out, no SRQ reply:
    this is the summarised log (now with a TCP-IP instrument connection (VXI))
    I don't get an SR. It times out
    (I lost a comment - retrying)
    I managed to get a log from DMM6500, over usbtmc, with NI VISA Interactive Control
    this explains 0x81 + status byte
  • ggabe
    0 ggabe over 2 years ago
    Jan - do you still need help? I do not have a suitable SRQ capable device. If more testing is needed I suggest the EEVBlog metrology forum.
  • Gough Lui
    0 Gough Lui over 2 years ago
    Hi Jan - sorry, I've been a bit tied up this week as I'm giving lectures at the university and I've got a few major projects in-flight.
    Perhaps if you give me a week or two, I can try if you still need it.
    - Gough
  • baldengineer
    0 baldengineer over 2 years ago
    I'm working on a video project this week. If I get a free moment while I'm at the bench, I can try this on my R&S HMC power supply. It has USBTMC, and I suspect it supports SRQ properly.
    If not, I *might* be able to GPIB an older instrument. If I can remember where my knock-off Agilent GPIB to USB adapter is. :)
    +1 Jan Cumps over 2 years ago in reply to baldengineer
