GIZMO 2
  • Single-Board Computers
  • GIZMO 2
GIZMO 2
Blog Gizmo2: 3D Printable Enclosure - First Iteration
Join GIZMO 2 to participate - click to join for free!
  • Author Author: fvan
  • Date Created: 26 Jan 2015 9:39 PM Date Created
  • Views 2595 views
  • Comments 11 comments
  • enclosure
  • gizmo2
  • 3dprinting
  • printrbot
fvan
fvan
26 Jan 2015
  • Introduction
  • Design
  • Print
To protect my brand new GIZMO 2 board from the pointy and metal objects (and the rest of the mess) scattered around my desk, I decided to design a simple 3D printable enclosure for it, which would still expose all interfaces. I'm no professional designer, so it's more a functional enclosure rather than a fancy looking one image
I took various measurements of the board, especially around the ports and started porting this to SketchUp.
Design
This is what the first version of the design looks like:
As I said, the focus is more on the functional side of things. The enclosure has following "features":
  • access to microSD card
  • 1cm standoffs, allowing room for mSATA/mini PCIe device
  • opening for high and low speed card edge connectors
  • opening for all ports: power, hdmi, USB3, audio, USB2 & ethernet
  • removable lid with an opening for the fan
I've attached the SketchUp files to this post in case anyone wants to build further from this. After printing, I'll check which adjustments need to be made and
Print
Having finalised a first version of the model, I tried to print it. The heated bed on my Printrbot was barely large enough, but it fit.
I enabled support material when slicing the model because of the many openings. After printing, I was able to easily remove it using small pliers.
There was a little lifting during printing, so the enclosure isn't totally straight, but it's still functional.
Here it is, in all its glory:
Power, USB and Ethernet access is OK. HDMI and audio are a bit off. I'll have to work on that for the next iteration.
Hope you like it! Feel free to provide feedback on the enclosure or make your own based on the files attached.
gizmo-bottom.skp.zip
gizmo-top.skp.zip
  • bwelsby
    bwelsby over 11 years ago +1
    A nice simple design, I like it... You have beat me to it I have been designing one using OpenSCAD and currently printing first prototype as I write this.
  • bwelsby
    You have beat me to it image  I have been designing one  using OpenSCAD and currently printing first prototype as I write this.
