Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Variants - Alternate Parts
  • Locked Locked
  • Replies 11 replies
  • Subscribers 92 subscribers
  • Views 3588 views
songshome
songshome over 9 years ago
I am trying to set an alternate part for variant, but there is no optinon for this in Variant Management ( only fitted, not fitted). If i try to set it from schematic editor, right click - part actions - choose alternate part, the pop-up window is all grey.
Am I missing something, or is this a bug?
Best regards
  • e14softwareuk
    e14softwareuk over 8 years ago in reply to diond31 +2
    If the regulators are directly compatible with absolutely no changes required to PCB or schematic then I would be tempted to just leave the one part and not worry about variants. A lot will depend on how…
  • e14softwareuk
    e14softwareuk over 8 years ago in reply to diond31 +1
    CS provides basic variant handling. You can have fitted / not-fitted and adjust the values / parameters of components but not have completely different components. Are the two components you are considering…
  • diond31
    diond31 over 8 years ago in reply to e14softwareuk +1
    HI Peter, Thank you for taking the time to reply. The LDO Voltage Regulators components are footprint compatible. Basically, need an alternate for supply chain reasons. What do you recommend for this situation…
  • pfreitas17
    pfreitas17 over 4 years ago
    Desperately clicking everywhere, finally found something...!
    Create your variant then in the Variant management window, right click on the variant name, the one in the lower part of the window (Component parameters) and select "update from library"
    Then select the library and component that you want on for the variant
    And select the parameters that you want to update and the variant on which to apply the changes
