Analog Devices
  • Analog Devices
Analog Devices
Forum What's So Special About 1-Wire Bus Technology?
Join Analog Devices to participate - click to join for free!
  • Subscribers 44 subscribers
  • Views 644 views
  • 1-wire bus
rscasny
rscasny over 8 years ago
Let's start with a basic question: What is 1-Wire Bus Technology?
The basis of 1-WireRegistered technology is a serial protocol using a single data line plus ground reference for communication. A 1-WireRegistered master initiates and controls the communication with one or more 1-Wire slave devices on the 1-Wire bus (Figure 1). Each 1-Wire slave device has a unique, unalterable, factory-programmed, 64-bit ID (identification number), which serves as device address on the 1-Wire bus. The 8-bit family code, a subset of the 64-bit ID, identifies the device type and functionality.
1-Wire is the only voltage-based digital system that works with two contacts, data and ground, for half-duplex bidirectional communication. In contrast to other serial communication systems such as I²C or SPI, 1-Wire devices are designed for use in a contact environment. Either disconnecting from the 1-Wire bus or a loss of contact puts the 1-Wire slaves into a defined reset state. When the voltage returns, the slaves wake up and signal their presence. With only one contact to protect, the built-in ESD protection of 1-Wire devices is extremely high. With two contacts, 1-Wire devices are the most economical way to add electronic functionality to nonelectronic objects for identification, authentication, and delivery of calibration data or manufacturing information.
Sound Interesting? Ready to learn more? then put March 21st on your calendar to attend a webinar by Maxim Integrated and Panasonic entitled A Deep Dive on the Maxim 1-WireRegistered Bus with Panasonic Grid-EYERegistered Sensor and Arduino-Compatible Building Automation Platform
