VPG Foil Resistors
  • VPG Foil Resistors
VPG Foil Resistors
Documents TN108: Non-Linearity of Resistance/Temperature Characteristic: Its Influence on Performance of Precision Resistors
Join VPG Foil Resistors to participate - click to join for free!
  • Author Author: DavidGazit
  • Date Created: 25 Feb 2013 11:19 AM Date Created
  • Last Updated Last Updated: 8 Oct 2021 5:24 AM
  • Views 573 views
“Non-Linearity of Resistance/Temperature Characteristic: Its Influence on Performance of Precision Resistors” by Dr. Felix Zandman and Joseph Szwarc presents test data showing how and why Bulk Metal Z-Foil resistors exhibit the lowest TCR over a wide range of temperatures and the smallest non-linearity of the ΔR/R = f(T) curve, or rate of change of TCR with temperature. This combination makes VFR resistors the best solution for applications requiring high stability of the ohmic value and/or of a ratio of values. Low TCR over a wide temperature range leads also to a reduction of resistance change due to the Joule effect reducing the thermal stabilization time regardless of ambient temperature and load.
imageTN108 Non-Linearity of ResistanceTemperature Characteristic.pdf
  • through hole resistors
  • Surface Mount Foil Resistors
  • Voltage Dividers and Resistor Networks
  • Power Current Sense Resistors
  • Military and Space (AMS)
  • Hybrid Chips and Custom Designed Hermetically Sealed Networks (PRND)
  • avionics
