Raspberry Pi Projects
Blog PIK3A Retro Gaming Table Mk II
  • Author Author: spannerspencer
  • Date Created: 22 Mar 2016 10:45 AM Date Created
  • Views 18659 views
  • Likes 12 likes
  • Comments 44 comments
  • retro gaming
  • rpibeginner
  • retro
  • pi3
  • pik3a
  • raspberry pi
  • raspberry_pi_projects
spannerspencer
spannerspencer
22 Mar 2016
I'm not a fan of Ikea. In fact, it's a place I usually try to avoid, until I discovered that you can hack it's ultra-cheap tables into retro video game systems! You know the one I mean: PIK3A: The Raspberry Pi 3 IKEA Retro Gaming Table.
You guys have been busy making your own versions, which I'm thrilled to be reading about. Keep those photos and top tips coming.
But in the meantime, meet PIK3A Mark II.
Hackin' the LACK
This is, in many respects, the same build as the PIK3A Mk I. The idea came about when I initially bought the square LACK tables that we mounted a monitor in, and added controls to. I was casually keeping an eye out for a table that'd accommodate two players, with six buttons each. You know. A Street Fighter II machine!image
There were definitely options, but the table size makes them prohibitively intrusive for the average living room. So I needed a way to reduce it, while maintaining the full control set.
The answer presented itself in the LACK TV stand; a narrow, 90cm by 26cm table that boasts a shelf and a table top deep enough to accept the joysticks and buttons. By dispensing with the monitor and going straight into the TV, the unit is easily accommodated in your average (well, as average as us element14 types ever really are) front room.
There isn't much to explain about the build that isn't already covered in the PIK3A Mk I. I cut two access holes in the bottom so I could get to the joystick and buttons for each player, and drilled start and coin buttons into the edge as before.
I kept the Raspberry Pi 3 external, mounting it in a case underneath the table top, in the centre. It's still nicely hidden, and there's only a short length of USB cable from the controls into the RPi. The benefits of this are that you don't need any extensions or panel mount connectors for the micro USB input or HDMI output. It also makes it easy to get to the SD card, should you need to.
There's no need for any acrylic or polycarbonate sheeting over the top either, given that there's no screen, making this a quick, simple yet highly effective variation on the PIK3A.
That said, one nice tweak might be coming up with a way to eliminate the HDMI cable and send the video to the TV wirelessly. Any thoughts on that?
  • stumcbill
    stumcbill over 9 years ago
    How thick / tough is the plastic on these tables? Could I use a dremel type tool to cut the holes?
    Is there a template available to overlay on top of the table to show where you guys cut the holes, or a schematic of the same?
  • spannerspencer
    spannerspencer over 9 years ago in reply to lordhalfrican
    Great to hear! Remember to show us the finished table!
    I cut out as little as possible, to try and keep some structure in the table top (although it doesn't hurt to reinforce it with some plyboard across the entire underneath). Anyway, I just cut two rectangles out, directly beneath each joystick and set of buttons. Then I mount the Pi in a case externally, so it's easy to get to the HDMI, power and USB ports and such, and just bring the cables out from inside the table.
  • lordhalfrican
    lordhalfrican over 9 years ago
    Awesome build! I'm planning on working  a version of this myself this week. I have a question for you. How much of the underside of the table did you cut out for access to the joysticks and buttons? Thanks!
  • dgfrommtl
    dgfrommtl over 9 years ago
    I hadn't seen this latest Ikeahack build - just the earlier one with the built in-screen on the square Lack table. The joystick and buttons I ordered on ebay came in yesterday, so I went to IKEA to pick up a LACK to just put in a controller for my PieCade  - and on my way to checkout - noticed this little TV stand. This is exactly what I wanted to do - use my TV and put the PieArcade inside. Thnaks the template - picked up a nice 1 1/8 forstner bit at Lee Valley tools - so time to measure and drill.
  • muuupi
    muuupi over 10 years ago in reply to e14 Contributor
    Did you already get the file for 6 Buttons?
