What products are you excited to get a hold of in the future? Is there anything out there you've been watching and just waiting to be released to get your hands on? Let us know!
Some small tester boards to go with those tools would be a good idea as you obviously need something to try them on before you start hammering expensive boards in anger
That device is often on a special with CPC I get the bumpf sheets come though once a week and you can sometimes bag similar stuff all going for 30-50% off nice to know if you are in the Uk at least
Even though I'd hate to miss out on the Network Analyzer, SMD tools would be very nice indeed.
-Steve
the Zero would be great, I have a load of projects that ended up too much for the UNO or too slow even where it would fit so one of these would be great to compare to and extend on... Should be fun
not sure what SMD tools were thinking of, i've already played with a few SMD device (Like when I blew up my road test Battery Pack and had to repair it ... Ooops)
now testing out a re-flow oven in the mix would make it a winner
Peter
Maybe E14 can do a kit of parts/tools/test board that demonstrate various components of soldering SMD
maybe with a few videos on E14. Basically a community supported kit
The Top members could put together a few tutorial videos to post in a common community area, great educational content and if it is using exclusively tools from E14, may even generate trade in the longer run
Exactly ...problem is that SMD tools can cover a big range of stuff, most of which not that interesting so if you want to give someone an SMD kit it needs to be co -ordinated around a deliverable ..like learn to SMD descretes, QFP, Highdensity devices in sort of sensible progression.
Then a micro-controller board KIT or something but also a couple of practice boards to learn
then once confidence and a few videos are done, build up your board and have a working practical end device...
