RoadTests & Reviews
RoadTests & Reviews
RoadTest Forum Would You Be Interested in Roadtesting KiCad EDA?
  • Blogs
  • RoadTest Forum
  • RoadTests
  • Reviews
  • Replies 77 replies
  • Subscribers 2648 subscribers
  • Views 9644 views
  • kicad
  • roadtest survey
rscasny
rscasny over 2 years ago
KiCad has a following on the element14 Community, so we figured it would be a good thing to roadtest. It's a little different than what we usually roadtest, so we have a few questions. KiCad is free, so we were wondering what the potential roadtesters would like to see in the roadtest kit. There was a suggestion for the roadtesters to design a Raspberry Pi HAT. But we could also use a Pi/Ardunio library or even someone's own design.
I have some polls below. I'd appreciate you voting. Thanks.
  • robogary
    robogary over 2 years ago +5
    Maybe a bit off the wall, but wouldnt a nice part of a road test include actually get a 5 pack of their fabs made for participants ?
    shabaz over 2 years ago in reply to misaz +5
    I suspect Design Challenges are intensive work, whereas Project14 is a lot lighter touch to support. It's a lot of effort to ship low-cost boards, so it might be better for any applicant to just swallow…
  • charlieo21
    charlieo21 over 2 years ago +4
    This sounds interesting but I'm not sure that the roadtest format is the best for this, maybe a design challenge could be more appropriate.
    dougw over 2 years ago in reply to cstanton
    Hmmm, I just checked and not all of my votes registered .... So I now made sure they did.
  • baldengineer
    baldengineer over 2 years ago in reply to cstanton
    Friendly reminder it is spelled “KiCad” and not “KiCAD” …
    Ironically EAGLE is spelled with all caps, or it was when CadSoft owned it.
    I presume the objective is to increase the number of people using KiCad, more than trying to increase the complexity of PCBs designed by existing users. Showcasing the learning experience of new users and entry level tutorials would be good for this, and both new users and seasoned veterans could do one or other of these approaches. I also like learn-by-doing methods because they add extra motivation to the exercise, so a real working PCB has more appeal to me. It shouldn't be too complex, as learning the tool is hard enough for a contest.
    PCB fabrication is pretty low cost these days, with some suppliers even offering the first proto order for free. So I don't think the logistical nightmare of element14 supplying board shop vouchers is worth it.
    As for supplying multiple spins of fabrication, that would make schedules too long, without adding much value. Everyone knows if you spin it enough times eventually you will get it right. If you have to hack up your prototype a bit to get it to work, that is interesting too, especially if you designed it to be hackable.
    Jan Cumps over 2 years ago in reply to shabaz
    shabaz said:
    I'm still working on the RA4M1 symbol, since it's a 100-pin part:
    KiPart is ideal for making high-pin-count schematic objects. If you have a list of the pins in datasheet or elsewhere:
     KiCAD lovers, check out KiPart
    Create my first KiCad part with KiPart utility
    my preference would be:
    • free to submit any design proposal in the road test application, not restricted to analog, microcontroller, hat, power, ...
    • a reasonable shopping cart for components
    • a pc manufacturer budget/voucher, allowing for several spins of a small board, or a single big board spin
    • creative freedom in the design and the format/content of the report
  • Andrew J
    Andrew J over 2 years ago
    I wasn’t sure how to vote on this one, perhaps I’m missing the point.  Isn’t “road testing” software essentially producing a tutorial on how to use it?  There are dozens of those already and Shabaz has a popular one on YouTube.
    Maybe an approach would be to look at this in terms of problem resolution - how well does KiCad fit into a set of (open-source) engineering applications, e.g LTSpice for simulation.   Define a complex problem that requires serious thought to layout and board setup, see how well KiCad supports the engineer in “getting there” with an iterative design approach.  Defining a component and its footprint in Kicad is a trivial exercise but board layout for, say, high-frequency, high-speed operation isn’t so how does KiCad support such a scenario and what tools are available to help?
  • BigG
    BigG over 2 years ago
    An interesting idea. As someone who chooses ease of use and simplicity I have struggled to convince myself to switch from EasyEDA to KiCad. Maybe this is what I need to see what all the fuss is about and give it proper structured evaluation.
    As far as format goes, I would limit the size of the printed circuit board to say no bigger than a raspberry pi or compatible hat because when it comes to design the challenge is using the power of the EDA, and it's design rules checking system, to handle the concentration and routing of traces. No doubt there are other design tools included in the KiCad package that should also prove whether something like KiCad is worth it's street cred.
    Similarly you could also place a limit of whether it's a 2 layer board or a 4 layer board. Maybe the road-tester can explore going more complex as an option but if fabrication is required that's usually a higher cost.
    As an offer, I think paying for the fabrication of the PCB would be nice. I am sure you have contacts with various vendors who could do this for you.
  • bfgelectronicspower
    bfgelectronicspower over 2 years ago
    I've worked with EasyEDA and Eagle but never tried KiCad, so i think this would be a fun challenge for me
  • anniel747
    anniel747 over 2 years ago
    A Protocase voucher?
    Jan Cumps over 2 years ago in reply to Andrew J
    It's documenting your experience while using it in the real world.
