RoadTests & Reviews
RoadTests & Reviews
RoadTest Forum Would You Be Interested in Roadtesting KiCad EDA?
  • Blogs
  • RoadTest Forum
  • RoadTests
  • Reviews
  • Replies 77 replies
  • Subscribers 2648 subscribers
  • Views 9645 views
  • kicad
  • roadtest survey
rscasny
rscasny over 2 years ago
KiCad has a following on the element14 Community, so we figured it would be a good thing to roadtest. It's a little different than what we usually roadtest, so we have a few questions. KiCad is free, so we were wondering what the potential roadtesters would like to see in the roadtest kit. There was a suggestion for the roadtesters to design a Raspberry Pi HAT. But we could also use a Pi/Ardunio library or even someone's own design.
I have some polls below. I'd appreciate you voting. Thanks.
  • robogary
    robogary over 2 years ago +5
    Maybe a bit off the wall, but wouldnt a nice part of a road test include actually get a 5 pack of their fabs made for participants ?
    shabaz over 2 years ago in reply to misaz +5
    I suspect Design Challenges are intensive work, whereas Project14 is a lot lighter touch to support. It's a lot of effort to ship low-cost boards, so it might be better for any applicant to just swallow…
  • charlieo21
    charlieo21 over 2 years ago +4
    This sounds interesting but I'm not sure that the roadtest format is the best for this, maybe a design challenge could be more appropriate.
  • suf
    suf over 2 years ago
    Using KiCAD for the last (I don't even sure) maybe 14 years. It would be great to test some newer features, edge cases. Just to push the limits a bit. :-)
  • beacon_dave
    beacon_dave over 2 years ago in reply to kmikemoo
    Looking at the ADALM2000 module, perhaps a 'T-Cobbler' style breadboard-friendly breakout board would be useful and a simple starter project ?
    Single 30way IDC ribbon from the ADALM2000 to a PCB that spans the central breadboard 'ravine' with two 15pin rows of thru-headers with clear labelling of all pins on the silkscreen.
  • Andrew J
    Andrew J over 2 years ago in reply to COMPACT
    I'm a bit late, but this is what KiCad does with multi-function parts, e.g. 4 op amp chips which separate each op amp and the power supply.
    shabaz over 2 years ago in reply to Jan Cumps
    Hi Jan Cumps  I tried KiPart, and followed your KiPart video - it was just what I needed.
    I managed to do this 64-pin chip in a fraction of the normal time! I specified in the CSV file which side I wished everything to be, and it's all perfect. I will move some of the left side pins around because I had not figured out the order at the time, but all other sides are exactly how I planned them to be.
    Jan Cumps over 2 years ago in reply to colporteur
    see  shabaz' work Arrow up
  • amitha_ntu
    amitha_ntu over 2 years ago
    PC104 OBC for Cubesat using FPGA
  • cstanton
    cstanton over 2 years ago in reply to amitha_ntu
